head stud?
head stud? Empty head stud?
Post  bigjohn2007 March 8th 2011, 1:37 am
arp make a head stud that will work with a-429 and p-51 or do have buy 2 diff. sets?thanks
bigjohn2007
bigjohn2007
head stud? Empty Re: head stud?
Post  Lem Evans March 8th 2011, 5:42 am
The P51 work best with the longer studs on the exh side and 12 point nuts.......the ones listed for blue thunder heads. the Standard ones can be made to work but will not be quite right.
Post  Gregaust March 8th 2011, 5:47 am
bigjohn2007 wrote:arp make a head stud that will work with a-429 and p-51 or do have buy 2 diff. sets?thanks
ARP 255-4301 is the number i used . Outers are 6-1/2" from memory, where the normal 460 head studs are only 6-1/8". Inners all the same in both sets
Gregaust
Post  richter69 March 8th 2011, 10:53 am
I used my std. studs on my P51's and they worked fine. I used 12 pt nuts in the top row and the 6 pts on the bottom.
Post  bigjohn2007 March 8th 2011, 6:24 pm
so if you had the blue thunder head bolt it would work on both trying to buy once instead of twice.
bigjohn2007
bigjohn2007
Post  Lem Evans March 8th 2011, 7:13 pm
You want bolts or studs? ARP has a bolt kit that is much cheaper than the stud kit.
Post  bigjohn2007 March 8th 2011, 8:21 pm
Lem Evans wrote:You want bolts or studs? ARP has a bolt kit that is much cheaper than the stud kit.
like the studs
bigjohn2007
bigjohn2007
