dove block splayed caps , eagle h beams, srp pistons
HELI-ARC
fe50stang
I got a .040 dove block with spayed center 3 main caps that I can't do anything with. The block will need to be line bored as the caps were installed but not final machined.
I bought this block from a forum member a while ago and was told it was standard bore. I just got my roating assembly with .030 pistons and took everything to machine and found out the bore is +.040 and my pistons will not work. At this point a block is cheaper then new pistons. so thats the route I will go.
$600 plus shipping from 97006 Portland Oregon
I also have a set of used eagle h beam rods 6.800 and a set of srp pistons flat top with a +.030 bore that fit a 4.300 crankshaft and standard heads / a429 $500 +shipping
thanks Justin 503 412 8141
Last edited by fe50stang on March 9th 2011, 9:18 pm; edited 1 time in total (Reason for editing : added pictures)
fe50stang- Posts : 132
Re: dove block splayed caps , eagle h beams, srp pistons
heli arc I Just seen your PM . I must have skipped over it. I'll add some pics of the skirts tomorrow. and BUMP>>
block sold . RODS and PISTONS are still up for grabs
mind if I ask, who made the splayed caps?
I'm looking for a set for my d0ve block as well
thanks
DV
thanks
DV
danev2- Posts : 49
I was told that they were milodon caps. But my machiest said the procomp caps are great for the price. He said the milodon caps are increadible hard. And kind of a bit@# to machine. Hopfully i dobt get beatup to bad fot saying the procomp word
71torino- Posts : 60
are the rods still for sale?
1Bad91- Posts : 267
Rods and pistons both are still for sale. Thanks justin
what size are your ends on the rods?
1Bad91- Posts : 267
Call me...757-630-3408
1Bad91- Posts : 267
could check with Eagle , don't think they have Ford specs on the 6.800 rods BBC only1Bad91 wrote:are the rods still for sale?
DanH- Posts : 1081
» D1 block, 4 bolt caps, pistons SOLD
» D1ve vs Dove block with 4 bolt caps????
» USED EAGLE H-BEAMS
» NIB Eagle H-Beams
» I'm looking for splayed 4-bolt main caps...
» NIB Eagle H-Beams
