can you run 11:1 compression on street with pump gas??
LivermoreDave
tiger
can you run 11:1 compression on street with pump gas?? Empty can you run 11:1 compression on street with pump gas??
Post  tiger March 15th 2011, 11:00 am
I am curious if you can run an 11:1 engine with cast iron heads on it on the street with 93 octane gas. If a cam grinder custom grinds a cam will it be able to or is it just to much compression?
engine is a 552 ci, fully ported D3 heads, headers, 1150 dommy, new TFS intake, zero decked, flattop pistons, fox mustang car, 4.11 gears, 3,000 stall, don't have cam yet.
tiger
can you run 11:1 compression on street with pump gas?? Empty Re: can you run 11:1 compression on street with pump gas??
Post  rmcomprandy March 15th 2011, 11:10 am
With a big enough camshaft, keeping the engine temperature down and well controlled ignition timing ... YES.
Post  LivermoreDave March 15th 2011, 9:47 pm
As "Rockin Randy" mentioned, I must concur!
Dave.
LivermoreDave
Post  dfree383 March 17th 2011, 7:48 am
Yep, cam be done with the right cam and good tuning skills.
Post  BOSS 429 March 20th 2011, 5:43 pm
x2
Post  johndickjr March 27th 2011, 10:45 pm
what about 12-1 with alum heads
johndickjr
Post  Ranch71460 March 28th 2011, 6:42 am
I'm using flat top diamond pistons and P51's with around 12:1 compression.
I use a 91 octane 10% ethamol blend of gas we have here in Alberta from Huskey with no issues.
Ranch71460
Ranch71460
Post  dfree383 March 28th 2011, 7:49 am
Altitude also comes into play...
