need a voltage regulator???
need a voltage regulator??? Empty need a voltage regulator???
Post  bb429power March 22nd 2011, 5:42 pm
Well I got my pit bike setup for the drags, I got a light on it so I can see better in the pits when it gets dark (sounds reasonable to me). Well I hooked up a unniversal fog light up to it, it worked great and got bright! The next day I started it, no light. The light bulb took a duce somehow because it was working until the point where I shut it off. Put a new bulb in it with an inline 5 amp fuse, worked for a couple seconds and blew the bulb. So is there something I can use to regulate the voltage going to the light? Its obviously putting out some voltage and I need a way to keep it at 12V.
bb429power
bb429power
need a voltage regulator??? Empty Re: need a voltage regulator???
Post  bb429power March 30th 2011, 9:18 pm
Okay, its putting out more than 3 amps but less than 5 amps. With 5 amp fuses the bulb will blow but with 3 amp fuses the fuse will blow.
bb429power
bb429power
Post  342g March 30th 2011, 9:41 pm
bb429power wrote:Okay, its putting out more than 3 amps but less than 5 amps. With 5 amp fuses the bulb will blow but with 3 amp fuses the fuse will blow.
Put a four in it, Laughing is that what you wanted to hear.
342g
342g
Post  bb429power March 30th 2011, 9:56 pm
Wise guy eh? You know what we do to wise guys? Razz If I can keep it at 3 would be happy, I really have no clue why it worked and I got it really bright with the original bulb, then the next day it wouldn't work. Since then every bulb has burned out pretty quickly. I was told I need a rectifier Idea sounds dirty Laughing I will ask my old teacher tomorrow, he's also an electronics teacher.
bb429power
bb429power
Post  res0rli9 March 30th 2011, 11:22 pm
Dont get your rector fried Razz
Post  69F100 April 2nd 2011, 1:50 pm
Justina it not the amp blowing the light it is the volts take a dc volt meter and see how many volts you are putting out.A motorcycle headlight is different than a regular car or truck headlight.
Jim
Post  bb429power April 3rd 2011, 12:28 pm
69F100 wrote:Justina it not the amp blowing the light it is the volts take a dc volt meter and see how many volts you are putting out.A motorcycle headlight is different than a regular car or truck headlight.
Jim
Okay Jimanda,will do Razz It is a unniversal fog light (mainly for a truck), my teacher seemed to think I was getting too much flow (OHMS) because the light itself is supposed to withstand 10 amps. I tried checking the voltage but its set up weird, I think the two wires going to it are both power wires, its just completing a circuit.
-Thank you guys, and thank you for moving this to the General Discussion for me.
bb429power
bb429power
Post  f250mike April 10th 2011, 10:19 pm
Hey Kiddo I think this is what you need.
https://www.dbelectrical.com/p-5612-new-rectifier-regulator-briggs-stratton-192400-196400-abs6000.aspx
Might be able to find a used one on a junk riding mower engine or new at your local TSC, Rural King, Farm Fleet, etc..
The 2 wires on the plug go to the stator, the other is your 12 volt output.
Good luck
mike
f250mike
f250mike
Post  bb429power April 12th 2011, 8:29 pm
Cool, thanks mike. That seems to be the best option.
bb429power
bb429power
