checking voltage drain
when checking for voltage drain on a vehicle , you disconnect the neg cable and hook up a test light , if its normal the light is barely on , if its high its bright, anyway i did this but not sure what normal is..so i am trying to hook up my multimeter, but not sure what to put the dial on
johndickjr- Posts : 896
Re: checking voltage drain
Not sure of your VOA meter but it should be set on DC volts.
I always thought with any kind of drain the test light would be on and you don't want it on
there is always some drain...with newer cars--trucks..with the digital stuff..radios..computer memory...etc..but it should be very low..just not sure how low or high..my 2003 caravan , it has a bad battery or it has a drain..having battery tested tomorrowbigblockfox468 wrote:Not sure of your VOA meter but it should be set on DC volts.
johndickjr wrote:there is always some drain...with newer cars--trucks..with the digital stuff..radios..computer memory...etc..but it should be very low..just not sure how low or high..my 2003 caravan , it has a bad battery or it has a drain..having battery tested tomorrow
Yeah I agree....I didn't think about this newer crap with the digital, alarm etc etc stuff
had battery tested it was badbigblockfox468 wrote:johndickjr wrote:there is always some drain...with newer cars--trucks..with the digital stuff..radios..computer memory...etc..but it should be very low..just not sure how low or high..my 2003 caravan , it has a bad battery or it has a drain..having battery tested tomorrow
» Ignition voltage
» need a voltage regulator???
» Engine ignition voltage.
» What pan is this?
» Oil Drain backs
» What pan is this?
» Oil Drain backs
