Intake gaskets
+9
quick 52
JACKAZZFLATZ
GaryS
10SHOTS
Beast
Gregaust
kjett
g612gr
13 posters
Intake gaskets
I put on a set of Victor intake gaskets......been battling a miss finally found out it was the intake leak on #1. I have Ford SCJ Heads and a Edelbrock Air Gap....these looked a little small and I didn't notice it when I put it together. Any recommendation on what brand to use?
g612gr- Posts : 13
Re: Intake gaskets
I like my Felpro 1231 gaskets. Use a little rtv around the water holes as extra measure and no issues for me!
kjett- Posts : 1169
Re: Intake gaskets
Victor Reinz 95074SG are the best . I got onto them by guys recommending them on here .. The 1231's are only for short term use , junk for extended use .
Gregaust- Posts : 625
Re: Intake gaskets
Where did you buy those from Greg? $?
Beast- Posts : 66
Re: Intake gaskets
kjett wrote:I like my Felpro 1231 gaskets. Use a little rtv around the water holes as extra measure and no issues for me!
x2
BOSS 429- Posts : 2371
Re: Intake gaskets
g612gr wrote:I put on a set of Victor intake gaskets......been battling a miss finally found out it was the intake leak on #1. I have Ford SCJ Heads and a Edelbrock Air Gap....these looked a little small and I didn't notice it when I put it together. Any recommendation on what brand to use?
http://nowearracing.com/intakegaskets.html
10SHOTS- Posts : 587
valley pan style intake gaskets
I've had a question about intake gaskets for quite some time. Since cooler intake air is a good thing, why not use a heat shield (valley pan) like what was used in the OEM 351M, 400M, 370, 429, and 460 applications???
GaryS- Posts : 114
Re: Intake gaskets
Always used the 1231's. Had lotsa problems with gasket tears and leaks. Went to 1231 S, with the metal sandwich design this year to see how they hold up.
JACKAZZFLATZ- Posts : 249
Re: Intake gaskets
mr gasket
dragweek quickest street rod 2009 2010
quick 52- Posts : 612
Re: Intake gaskets
X3 Never had any issues with these gaskets.
BigDave65- Posts : 567
Re: Intake gaskets
Beast wrote:Where did you buy those from Greg? $?
I get them from Carquest in the U.S when visiting there .. .. Never seen them local
Cost was $42.39 for the CJ ports 95074SG and , small port 95109SG $38.98 purchased from Carquest , Orange California
Will see if i can find the links to the older forums that had all the info.. The 1231S with the steel core i believe would work ok. The 1231 gaskets are apparently teflon coated to not stck for easy regular removal, and problem is if left on for any length of time they creep between the smooth aluminium surfaces and leak.. So far the Victor Reinz gaskets have worked great for me .
Re: Intake gaskets
I should have mentioned also i have used the blue Felpro intakes successfully for the small port heads . One set i removed after about 12 years and they looked like new ..
Some previous info , Unfortunately some of the links contained within are to the old board and don't work. Lots good info here from several guys with lots of Experience.
http://www.460ford.com/forum/showthread.php?t=121304&highlight=intake+gaskets
http://www.460ford.com/forum/showthread.php?t=120374&highlight=intake+gaskets
http://www.460ford.com/forum/showthread.php?t=129605&highlight=intake+gaskets
http://www.460ford.com/forum/showthread.php?t=149682&highlight=intake+gaskets
http://www.460ford.com/forum/showthread.php?t=131417&highlight=intake+gaskets
http://www.460ford.com/forum/showthread.php?t=133941&highlight=intake+gaskets
http://www.460ford.com/forum/showthread.php?t=136633&highlight=intake+gaskets
http://www.460ford.com/forum/showthread.php?t=139397&highlight=intake+gaskets
Re: Intake gaskets
Lem Evans wrote:The SCE intake gaskets work good also.
X2
Re: Intake gaskets
X 3 on the SCE gaskets. I've never had any problem with them and Lem has them in stock for the SCJ, A-460 and C-460 heads.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
