Need help on oil pump...
+6
D. Sea
'65 T-BOLT
bigunitmudracing
10 posters
Need help on oil pump... Empty Need help on oil pump...
Post  bigunitmudracing March 22nd 2011, 11:02 pm
I did the oil mod where you drill out hole from 1/2 in to 9/16in and champhered the edges of where the oil goes to the pump and filter.. MY question is what pump do i run now on the motor ... 6500 rpm , high compression good parts...thanks
bigunitmudracing
bigunitmudracing
Need help on oil pump... Empty Re: Need help on oil pump...
Post  '65 T-BOLT March 22nd 2011, 11:03 pm
Kasse pump! you can get one from Lem Evans
'65 T-BOLT
'65 T-BOLT
Post  cool40 March 22nd 2011, 11:24 pm
'65 T-BOLT wrote:Kasse pump! you can get one from Lem Evans
x10! Very Happy
Post  bbf-falcon March 23rd 2011, 12:31 am
The Kaase pump really is a good investment for many reasons,
1. Its very beefy and won't break off like some of the others
2.It is very well engineered
3. Its a good sleep aid (no worries about it's performance) Very Happy
Post  bigunitmudracing March 23rd 2011, 8:35 am
anyone have a part number on the kasse pump??
thanks
bigunitmudracing
bigunitmudracing
Post  dfree383 March 23rd 2011, 8:36 am
Call Lem at BF Evans Ford he had 3 or 4 of them on the shelf last week.
Post  '65 T-BOLT March 23rd 2011, 11:52 am
B.F.Evans Raceparts...1-877-611-2613 ask for shawn in parts!
'65 T-BOLT
'65 T-BOLT
Post  bigunitmudracing March 23rd 2011, 12:25 pm
Called... I'm assuming its nothing like a $40 mellings pump... the kasse is $250.
Just wondering what is so much different... I am planning on getting one but just want to know y you guys like them so much....
bigunitmudracing
bigunitmudracing
Post  D. Sea March 23rd 2011, 12:27 pm
The Kasse pump is much better engineered and much stronger.
If possible, this weekend I'll try to stream or upload some video from a previous tech seminar about the Kasse pump.
D. Sea
D. Sea
Post  bigunitmudracing March 23rd 2011, 12:38 pm
that would be great!!
thanks
bigunitmudracing
bigunitmudracing
Post  72puller March 23rd 2011, 1:28 pm
click here
http://www.jonkaaseracingengines.com/component/content/article/40-kaase-products/190-kaase-pump-big-block-ford-oil-pump.html
72puller
72puller
Post  the Coug March 23rd 2011, 1:33 pm
Break one of those $40 dollar one and trash everything you put in that engine and you will know why we like the Kaase pump.....
Post  dfree383 March 23rd 2011, 1:36 pm
the Coug wrote:Break one of those $40 dollar one and trash everything you put in that engine and you will know why we like the Kaase pump.....
X2 it sounds expensive untill one of the $50 pumps cracks and causes Thousands in damage.......
Post  rmcomprandy March 23rd 2011, 1:55 pm
bigunitmudracing wrote:Called... I'm assuming its nothing like a $40 mellings pump... the kasse is $250.
If you're looking for lightweight then the Kaase pump isn't for you because, it weighs twice as much as a Melling oil pomp.
Besides the fact that the Kaase pump is cast from DUCTILE IRON instead of regular CAST IRON and the inlet fills the pumping element from BOTH sides not just one side; the pump pedestal, (the part that breaks), which bolts to the block is about 3" wide by 1 1/4" thick and a Melling is about 1 1/8" and near round.
Post  whatbumper March 23rd 2011, 2:00 pm
you can find peterson pumps used for pretty cheap considering what they do.
Post  bigunitmudracing March 23rd 2011, 5:25 pm
72 puller,,, thanks..
Guys i'm not looking for cheaper at all, and dont care about weight. i just wanted to know the difference...
bigunitmudracing
bigunitmudracing
Post  the Coug March 23rd 2011, 5:42 pm
for what it is worth when I changed I noticed the oil PSI was now steady. where before it fluctuated.... the pump is stout some cranks need to have the pump slightly clearanced. but no biggy.... and you sleep with piece of mind knowing you have it in there vs the Melling.....
