Loose rocker arm
Loose rocker arm
I went to readjust the valves and noticed a rocker arm nut was backed off and where it was running the tip that goes into the rocker has worn flat. it seems the rocker was flopping around. The rocker is scuffed. I am going to either get a new pushrod if I can or buy a whole new set. Mabe I will get intrested to go back out and work on it later.
Anyone had this happen before?
Re: Loose rocker arm
yes i was in drag week last year and we were on day 3 at milan mi.. finish up racing and headed pitt. pa. race track. andall of a sudden my engine started running roug and clattering like hell. pull over and removed the valve cover a intake rocker was very loose . thought the lock nut had loosen but was still tight. i removed the rocker and the top of the push was gone. we were in the middle of BFE at 5.00 pm. trying to think how to get a push rod or fix the one we had. when one of the unlimited car pulled up and said do u need help. i said do u have any push rods he said yees but hes running a chevy i said may work i run 8.750. he said can u run 8.800 i said hell yes 20 minutes later we were running down the road the pitt. pa. . i ran that push rod for 2 more days and won drag week quickest street rod with. his Todd Maschmeier camaro won modified power-adder 7.96 @ 173.54and i have one of his push rods. anyways long story the push rod mfr. said it was a heat treating problem.
dragweek quickest street rod
2009 2010
2009 2010
quick 52- Posts : 612
That was nice work and good luck.
bigjohn2007- BBF CONTRIBUTOR
I am gonna get ahold of Lem and see if he has any more SCJ pushrods that he could sell 1 at at time.
SCJ pushrods are all gone. I ordered some comp hi-tech pushrods and a few to keep as spare. Time to install these and get my new Jomar stud griddle instaled as well.
you can buy right from the MFR. comp doesnt make them. diamond or mall tooling make most of the push rods.
Mall tooling & eng. 586-463-6520 half the price but you need to no your size. buy 10 or 2 they will laser the size if you ask
» C9 heads solid flat tappet cam rocker loose when tightened . Need advice
» Acceptable roller rocker contact at valve tip and pushrod to rocker contact?
» How many cc do you loose milling dove heads .040??
» Big lobe & lower ratio rocker or smaller lobe & high ratio rocker? whcih will live and which makes more power?
» Converter might be loose?
