Converter might be loose?
norm
ultimatelenny
westsideford
Converter might be loose? Empty Converter might be loose?
Post  westsideford September 16th 2009, 1:15 am
Hey,
Got the new converter and it's a 4K Stall. Here is the In-car vid from Pinks.. My old converter was a 3K stall & between shifts it went to 3K..
I'm thinking the converter is too loose! What do ya think?
Converter might be loose? Th_100_0343
westsideford
westsideford
Converter might be loose? Empty Re: Converter might be loose?
Post  ultimatelenny September 16th 2009, 7:41 am
Hi, could we get a little more info on your set up? How much actual stall are you seeing? It doesn't seem to fall back too far on the shift, if you can post more info, it would help.
ultimatelenny
ultimatelenny
http://www.ultimateconverter.com
Post  westsideford September 17th 2009, 12:39 am
ultimatelenny wrote:Hi, could we get a little more info on your set up? How much actual stall are you seeing? It doesn't seem to fall back too far on the shift, if you can post more info, it would help.
What do you need to know?
521 running a C-4 trans with 3.27 gears.. ??
westsideford
westsideford
Post  richter69 September 17th 2009, 8:13 am
How much rpm drop on the shift, and what rpm in the traps Les.
Post  DILLIGASDAVE September 17th 2009, 8:40 am
And cam & carb specs will help him.
Post  westsideford September 17th 2009, 11:35 pm
richter69 wrote:How much rpm drop on the shift, and what rpm in the traps Les.
Well If I watch the incar video.. I shift @ 6300 and it looks like it drops to 4500? I thought 4K was a choice spot for the cam but it looks like maybe the converter is dropping only to 4500? It's maybe not a bad thing because I might go up in cam with aluminum heads.
The car sounds like a Lenco Transmission.. I guess it's good?
Watch the tach in the video..
Last edited by westsideford on September 17th 2009, 11:42 pm; edited 2 times in total (Reason for editing : spelling)
westsideford
westsideford
Post  norm September 18th 2009, 12:43 am
sounds like it flares going into 3rd,also.
norm
norm
Post  richter69 September 18th 2009, 6:25 pm
I guess my eyes are too bad Les to see the tach.
Your direct clutches would appreciate it if you wouldn't neutral the tranny at the end of the run......... Very Happy
Post  westsideford September 19th 2009, 12:04 am
richter69 wrote:I guess my eyes are too bad Les to see the tach.
Stick her in "N" to make sure ya got oil to the motor. "G" Forces!
Talk to me big ski daddy! Rule of thumb was to keep oil to the motor! Was I wrong?
Last edited by westsideford on September 19th 2009, 12:12 am; edited 1 time in total (Reason for editing : added info)
westsideford
westsideford
norm wrote:sounds like it flares going into 3rd,also.
Tell me more! "H" servo..
westsideford
westsideford
Post  richter69 September 19th 2009, 12:35 am
You must not race on any "short" shutdown 1/8th mile tracks ............. Laughing
Post  nuclearcobra October 11th 2009, 6:51 am
Ya dont need to throw it in neutral at the end Les, if your oil guage is dropping at the end which i hope its not then its some other problem then g forces. I raced my cobra two for years pullin the wheels up there with 1.40 60' shifting at 7k with a stock front sump pan and pump and never hurt anything maybe im just lucky i dont think most racers throw it in neutral over the stripe.
nuclearcobra
nuclearcobra
Post  DFI429 October 11th 2009, 9:29 am
x2.. sounds like a stick car Shocked
DFI429
DFI429
Post  the Coug October 11th 2009, 9:38 am
definately high gear flare when you hit high gear the shift light stays on for a few seconds....
Post  ThndrChkn October 11th 2009, 10:52 am
Kinda sounds like my C6 did when it flared up, only a little worse... With my Glide, it only drops about 1000-1100 rpm on the shift, right where Lenny said it should be... And on kickin' it to neutral, I was told (with the Glide) it would make it easier on the dizzy gear retaining pin if I hit neutral at/after the stripe...?
Doug... Cool
ThndrChkn
ThndrChkn
