Intake ?'s with Blue Thunder heads
23Alt
342g
schmiddy
I have a set of aluminum Blue Thunder heads with the Chevy exhaust ports. I'm rebuilding the engine right now for my boat and want to replace the dual plane low rise with a high rise single plane. Will a normal CJ intake fit the heads or do I need to buy a Blue Thunder specific intake?
Any suggestions or recommended products for my application would be hugely appreciated.
schmiddy- Posts : 13
Re: Intake ?'s with Blue Thunder heads
Quick, somebody answer this question, I need to know this answer myself.
342g- BBF CONTRIBUTOR
Guys,
Buy the new TFS Mafia single plane (4500 Dommy style) from Lem. It's the best manifold out there for those heads.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
Yep, CJ buttons right on.
23Alt- Posts : 33
OK ....went to the TFS site and they aren't listed. So where can I buy/shop for one?
schmiddy wrote:OK ....went to the TFS site and they aren't listed. So where can I buy/shop for one?
Lem has them
res0rli9- BBF CONTRIBUTOR
OK, Lem? you out there?
Here.
http://www.460ford.com/forum/showthread.php?t=152679
What's the difference between the
TFS-53400112 & the TFS-53400111?
Just the carbureter?
schmiddy wrote:What's the difference between the
They are completely different manifolds; especially inside.
To simplify it, One is for CJ sized intake ports and has a Dominator carb flange and the other is for regular size production intake ports with a 4150 carb flange.
Depends on the Hp and RPM levels.........some appliations would be better served with a Torker II .schmiddy wrote:
Will my victor bolt up Lem?
Lem Evans wrote:The Victor will bolt on the the BT heads.
Thank you.
Will a Weiand tunnel ram fit these heads? I have a set of BT's here that I'm thinking about putting on my 532. Would like to retain my intake if at all possible.
busta- Posts : 28
Yes the TR will fit.
busta wrote:Will a Weiand tunnel ram fit these heads? I have a set of BT's here that I'm thinking about putting on my 532. Would like to retain my intake if at all possible.
As long as that tunnel ram is for a wedge and not meant for the BOSS engine, it will fit.
» Help W/ Heads & Intake choice, go "Blue Thunder"??
» IRON Blue Thunder Heads ( complete ), Intake & Carb
» DISTRIBUTOR FOR BLUE THUNDER 2 PC. INTAKE
» Change of intake for my street car
» Question: Blue Thunder 2x4 intake
