E4OD trans brake
Greg_P
Page 1 of 2
Page 1 of 2 • 1, 2
E4OD trans brake
Is there anyone making such a thing?
Greg_P- Posts : 1009
Re: E4OD trans brake
I hope not!
What are your plans, Greg?
windsor- Posts : 1167
Seems like lentec does.
That e4 is a heavy, power robbing sob.
I'm planning to put an E4OD in the Torino over the winter.
'cause I need more weight in the car.....
Nah, my goal is to put 2000 street miles on the car next year, and I ain't gonna harsh myself by not having overdrive.
Hopefully I can sell my two C6's... both broader performance fully rollerized deals... and my converter and have the $$$ to get a trans controller and a converter for the E4OD I already have here.
Greg
Greg
ok if your after the o/d deal then I can see it.
I han considered developing a tb for the e4/4r at one time for the diesel fags, lost interest in it.
The converter may take some doing.
I see you already have an E4OD... but not wanting to try the AOD? Won't need a control box with that and only the throttle valve cable... You'd definitely save some weight and AOD's nowadays are quite proven behind high HP motors.
Plus, that JW adapter bellhousing is a nice piece and fits well.
But, you probably already knew all of that
Here is the link to the E4OD page on Lentech's website http://www.lentechautomatics.com/4r100products.html#
Either way, sounds very cool!
Wow, that brake valve body is $779 bucks! Ouch!
How about the gear venders OD unit??
hotrodmerc- Posts : 46
Yep...seems everything from Lentech is expensive.
Gearvendors is definitely expensive and I think it negates Greg's idea of selling his current trannies to pay for what he wants to do? Supposed to be nice units, however.
FWIW, I bought my AOD with a manual and transbraked Lentech VB, and all the fancy upgrades completely fresh for $1400. It was in a twin turbo small block car running 9.20's. Have about $500 additional with adding the JW Bell for a total of around $2000.
I do not see an AOD putting up with the torque of the 545 combined with the weight of my car.
A gear vendors would be OK, but I'd have to cut up the floor in the car and would overheat the trans with the high stall non lockup converter.
I already have the E4OD, and if I'm gonna have to cut the car to make anything fit, I might as well install a known bulletproof trans with a lockup converter.
At least that's my thinking.
The E4OD seems like a very strong trans. If the weight is a problem, I'll up the spray....lol.....
Greg
Greg
Cool...let us know how it turns out! I think you may be the first to try it in that capacity
heres a link of stuff that may be of interest to you. No trans brake but some cool electronic control stuff..
http://www.suncoastconverters.com/ford/e4od/fprode4od.html
Diggindeeper- Posts : 800
Sweet Mary Mother of Blessed Acceleration, that controller's 1,300 bucks! WOW!
The Baumann unit is 450 bucks and does 10x more than I need.
Greg
Greg
LOL i didnt even see the price. As i was postin the link i was thinkin "i wonder how much this thing costs"
what kind of power will a warmed over E4OD take?
how much power do they soak up?
what do they weigh in comparison?
windsor wrote:what kind of power will a warmed over E4OD take?
According to Jay at Broader Performance, the E4OD should be able to take the same power as a C6.
As far as power loss, I have no clue, but with more crap in there to turn I can only assume the loss would be greater than a C6.
The E4OD is super frickin heavy, and using the slipped disc scale for reference, the E4OD probably weighs 75 lbs more than an AOD.
holy chunk of iron, batman! That's a lot of weight...but what's another 75lbs on your sled, right?
OD is the only way to go!
All I know is when I had to redo the E4OD in my truck last year (thanks Jon and Jay) I had to make this jig to hold the darn thing while I assembled it.
I then had to use my cherry picker to get it down off the engine stand!
Why won't someone develop a manual valve body for the E4OD. Put OD on a switch. They have them for the 4r70w, why not the E4OD? I would be all over an E4OD if someone would build a manual valve body for it.
dablack- Posts : 18
They already work this way...........sorta.
For a full manual deal I'll build you one for say 10,000 dollars...lol, the second one would be a good bit cheaper.
I'll put dibs on the second unit.
Oh no Greg. You started the thread. You are obviously in line ahead of me. I'm fine with the second one. You may have all the glory of being first.
Really though, I would be happy with simple toggle switches or push buttons. How about a little up and down shifter like on a motorcycle? My left foot isn't doing anything anyway!
The price of the trans, price of the rebuild, and price of the controller, puts it just out of my budget.
dablack- Posts : 18
the shifting is no big deal to control, its the line pressure that has to be reglated somehow, the controllers are out there its just the cost lol.
Page 1 of 2 • 1, 2
» Trans brake
» Trans Brake vs Foot Brake
» C6 Trans brake
» Trans brake
» How can I trans brake my c6 without.......?
» C6 Trans brake
» Trans brake
Page 1 of 2
