Yes or no to running a thermostat with elec pump drive?
Treeyasoon
72puller
f250mike
Yes or no to running a thermostat with elec pump drive? Empty Yes or no to running a thermostat with elec pump drive?
Post  f250mike April 14th 2011, 4:49 pm
What are you guys doing?
Right now my engine has a 165* thermostat.
mike
f250mike
f250mike
Yes or no to running a thermostat with elec pump drive? Empty Re: Yes or no to running a thermostat with elec pump drive?
Post  72puller April 14th 2011, 6:00 pm
I don't run a thermostat anymore. Pump built up pressure when the thermostat was closed. Coolant leaked into the motor past the intake gaskets in the corners. If the thermostat had a small hole drilled in it you might be OK.
72puller
72puller
Post  69F100 April 14th 2011, 8:14 pm
Mike I don't run one for the reason when I pull back to the pit when I shut my engine off I leave the pump and fan running to cool it down for the next pass.
Jim
Post  72puller April 14th 2011, 8:26 pm
69F100 wrote:Mike I don't run one for the reason when I pull back to the pit when I shut my engine off I leave the pump and fan running to cool it down for the next pass.
That's want I do too. I have sensors on the fan and pump. Park the truck and let it circulate to cool down.
Dennis
72puller
72puller
Post  Curt April 14th 2011, 9:36 pm
absolutely not! Suspect
Post  Treeyasoon April 14th 2011, 11:16 pm
I run the blue Moroso restrictor in mine....I can put it back on the peg from 180* in about 8 minutes.
Treeyasoon
Treeyasoon
Post  BOSS 429 April 14th 2011, 11:31 pm
f250mike wrote:What are you guys doing?
mike
not in a race engine
Post  bbf-falcon April 15th 2011, 1:09 am
Knock the center out of the thermo on mine. Smile
Post  Race Ready Fabrications April 15th 2011, 7:23 am
bbf-falcon wrote:Knock the center out of the thermo on mine. Smile
X2
Post  whatbumper April 15th 2011, 9:00 am
We have never ran one and never will most likely. Use to bracket race the maverick in multiple classes every weekend so there were plently of times that the car never saw the pits, made a pass returned and got back in line for another class, and never had an overheating problem and that was with a factory pump with the moroso electric drive on it.
Now we run our intercooler water through the intake directly into the water jackets. The thermostat housing has a flat piece of aluminum with our temp sensor in it now. Rule 3700 moves lots of 60 degree water Cool
Post  f250mike April 15th 2011, 11:15 pm
Thanks guys
Great info as always.
Thermostat will be removed tomorrow.
mike
f250mike
f250mike
