Elec water pump question
butterbean
capncruncher1965
Elec water pump question Empty Elec water pump question
Post  capncruncher1965 February 26th 2015, 5:13 am
DO you guys run a thermostat on the street with a elec water pump or a restricker of some kind ?
capncruncher1965
capncruncher1965
Elec water pump question Empty Re: Elec water pump question
Post  butterbean February 26th 2015, 12:20 pm
I never have but I live in Florida, most electric water pumps turn 750 to 1000 RPM so I think with it turning that slow you don't need one but like I said i'm in the south where it just don't get that cold, good luck
butterbean
butterbean
Post  BigBlockRanger February 26th 2015, 12:39 pm
I use a gutted thermostat. Seems to work fine.
Post  dfree383 February 26th 2015, 1:19 pm
For just occasional street duty I'd think you be fine with or without a thermostat in it as long as you keep an eye in the temp, but for everyday use I wouldn't want an electric pump, Id go with a belt driven mechanical pump.
Post  Larry Williams February 26th 2015, 2:31 pm
there are temp sensors available to turn on the water pump
Larry Williams
Larry Williams
Post  Mustang-junky February 26th 2015, 9:37 pm
BigBlockRanger wrote:I use a gutted thermostat.  Seems to work fine.
Same here. Simple and cheap.
Jess
Mustang-junky
Mustang-junky
Post  sg86coupe February 27th 2015, 11:38 pm
I tried gutted thermastat worked OK, then washers with smaller hole, worked better until middle of summer. Then went back to factory water pump and themastat.
sg86coupe
