Holes in the intake ports that run into the rocker stud bosses?
nuclearcobra
Holes in the intake ports that run into the rocker stud bosses? Empty Holes in the intake ports that run into the rocker stud bosses?
Post  138 April 16th 2011, 12:01 am
tfs a460 heads.... what are these for?... just curious... and if the intake ports are that thin how can they be safely ported or cnc'd?
138
Holes in the intake ports that run into the rocker stud bosses? Empty Re: Holes in the intake ports that run into the rocker stud bosses?
Post  cool40 April 16th 2011, 12:50 am
my A460's are the same way.you wont have any problems with them.very little cutting in that part of the head for cnc anyway.
Post  138 April 16th 2011, 1:06 am
cool thanks...I figured they were "supposed" to be there...they are in every intake port, on both heads, and have been hit with some kind of grinder...
138
Post  nuclearcobra April 16th 2011, 7:24 am
Most heads i've seen are like that my scj's my world iron windsors and my kaase small block heads.
nuclearcobra
nuclearcobra
Post  c.evans April 16th 2011, 8:25 pm
Those holes are on 90% of the BB Ford and BB Chevy aftermarket heads that are out there. The manufacturers have to tap the hole deep enough and it breaks through the roof of the intake port. Just make sure you use some kind of sealer, such as pipe dope or RTV on the intake rocker studs, or the engine will suck oil through those holes and put out blue smoke.
Hope this helps,
Charlie Evans
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  wvmudder April 16th 2011, 8:56 pm
Good question, and thanks for the tip Charlie. A friend of mine (chevy guy) was fingering my A heads and told me they were F'ed up because of those holes. I told him i'm sure theres a reason for them. He then proceeded to assure me his Pro Comps didn't have them lol! . Needless to say I was no longer worried.
Dave S.
wvmudder
wvmudder
Post  138 April 16th 2011, 9:24 pm
c.evans wrote:Those holes are on 90% of the BB Ford and BB Chevy aftermarket heads that are out there. The manufacturers have to tap the hole deep enough and it breaks through the roof of the intake port. Just make sure you use some kind of sealer, such as pipe dope or RTV on the intake rocker studs, or the engine will suck oil through those holes and put out blue smoke.
Hope this helps,
Charlie Evans
will do... thanks charlie...
138
Post  Lem Evans April 16th 2011, 10:01 pm
Loctite is the best sealer...i.m.o.
Post  richter69 April 16th 2011, 10:15 pm
Lem Evans wrote:Loctite is the best sealer...i.m.o.
use the red.......... Wink
