will a stock c6 take this power
+9
PaulS
cooter
stanggt
whitefield
Tennessee Bullitt
tiger
13 posters
will a stock c6 take this power Empty will a stock c6 take this power
Post  tiger April 19th 2011, 5:23 pm
My new 547 has 700 hp, it has a 3,400 stall. I am going to drive it on street and strip. Will a stock c6 take this power, if not what changes need done?
tiger
will a stock c6 take this power Empty Re: will a stock c6 take this power
Post  738drvr April 19th 2011, 10:11 pm
Talk to Whitefield. He's your guy for questions.
Post  Tennessee Bullitt April 19th 2011, 10:26 pm
738drvr wrote:Talk to Whitefield. He's your guy for questions.
X's 2. I still get impressed with what he did to mine. I have beat this thing like a rented muel, it is still as good as the day I picked it up. Thanks Mike.
I would say no with that kind of power and torq.
Tennessee Bullitt
Tennessee Bullitt
Post  Frank Merkl April 20th 2011, 8:55 am
the stock C6 will take the power but not at the stock line pressure of 65psi it will need to be raised to 140-150 psi , replace the pressure spring in the VB with a baby blue rear brake shoe retaining spring will put it there.
Post  whitefield April 20th 2011, 11:42 am
Frank Merkl wrote:the stock C6 will take the power but not at the stock line pressure of 65psi it will need to be raised to 140-150 psi , replace the pressure spring in the VB with a baby blue rear brake shoe retaining spring will put it there.
X2 to what Franks advice was.Thanks guys for all of your praises
whitefield
whitefield
Post  stanggt July 13th 2011, 10:00 pm
what spring kit are you taking the spring from?
stanggt
stanggt
Post  cooter July 13th 2011, 10:31 pm
if a stock c6 wil take 700hp then why go through the expense of hardened input shafts, rollerizing, and other mods? Just courious,
cooter
Post  dfree383 July 14th 2011, 7:27 am
cooter wrote:if a stock c6 wil take 700hp then why go through the expense of hardened input shafts, rollerizing, and other mods? Just courious,
To make you feel good and so you can tell your buddies it's "Hot Rodded"..... Laughing Laughing
The rollerizing is to free up HP and make things better....
Post  cooter July 16th 2011, 10:01 am
I would amagine that the life of the tranny depends on what the application is but how long will a tranny last with a fresh rebuild with good clutches, a shift kit and pressure increase? I know this is a loaded question but i am just trying to understand c6s better as i am new to building higher hp ford trannys. Gm trannys i have done with good success.
cooter
Post  PaulS July 20th 2011, 4:45 pm
cooter wrote:I would amagine that the life of the tranny depends on what the application is but how long will a tranny last with a fresh rebuild with good clutches, a shift kit and pressure increase? I know this is a loaded question but i am just trying to understand c6s better as i am new to building higher hp ford trannys. Gm trannys i have done with good success.
With 700 hp all bets are off but a well built C6 with oem replacement clutches and band should last three years before needing to be refreshed. Using aftermarket carbon/kevlar clutches and bands and Mercon V fluid should run three to five years with weekend racing and driving daily as long as it is properly maintained.
You will need a lot of cooling to go with your converter - at least 35000 BTU (30000 GVW) with lots of airflow (in front of the radiator).
PaulS
Post  Gregaust July 21st 2011, 5:28 am
One i freshened recenty i built 13 yrs previous with lots street use , racing , dyno's etc , was seeing around 500HP, good basic build transgo -2 kit 4 clutches top gear 5 fwd + rev etc.
Gregaust
Post  stanggt August 25th 2011, 7:30 pm
Hi Frank, what kit are you getting this babyblue spring from? would like to add that to mine. Thanks
stanggt
stanggt
Post  69F100 August 25th 2011, 7:59 pm
Not sure if it is the same but my 69 F100 kit I put in it has the blue springs that hold the shoes to the backen plate
On my c6 all that I have changed on it is I put a B&M shift kit and 4000 stall by the racing cals I am putting 536 hp to the tires and never had a problem with miles is unknown it was a used Fred Jones reman that sit for a few years
Post  wvmudder May 13th 2012, 3:48 am
Hey guys, i hate to bring up an old thread like this, I have been looking over rockauto to no end. What is a part number of the correct spring? I bought Dorman part number HW1160, baby blue springs for foxbody brake shoes.
They are app 1 1/8" long, does that sound correct?
I hate sound like i'm asking to be spoon fed, but there are so many different brake shoe hold down springs.
Dave S.
wvmudder
wvmudder
Post  njstang87 May 21st 2012, 5:48 pm
wvmudder wrote:Hey guys, i hate to bring up an old thread like this, I have been looking over rockauto to no end. What is a part number of the correct spring? I bought Dorman part number HW1160, baby blue springs for foxbody brake shoes.
Dave S.
x2
njstang87
Post  Frank Merkl May 21st 2012, 7:29 pm
should be about right , should be , .700" in diameter - .070" diameter wire - and little over 1" long with 4 free coils
Post  njstang87 May 22nd 2012, 9:47 am
Thanks Frank
njstang87
