Look what I'll be workin' on........
Look what I'll be workin' on........ Empty Look what I'll be workin' on........
Post  ThndrChkn April 21st 2011, 11:18 pm
Look what I'll be workin' on........ 0421111125
Look what I'll be workin' on........ 0421111126a
My friend John asked if I'd put his new engine together. It's a 528" C-Headed, short deck A-460 block. 9.75" deck, 4.630" bore, 3.920" stroke, 6.385" BBC rod.
My only concern is, with the deck as short as it is, there are no more top bellhousing bolts holes. Is there going to be enough strength to mount a trans? Or is there something one can do with a mid-plate to be able to use the 2 top holes for the bell? I was looking at the A-500 block, and it looks like it uses a SBF bell...? But I don't think that would even be an option here...?
ThndrChkn
ThndrChkn
Look what I'll be workin' on........ Empty Re: Look what I'll be workin' on........
Post  cool40 April 21st 2011, 11:26 pm
pic's or it aint real. Suspect no top holes?
Post  ThndrChkn April 21st 2011, 11:43 pm
I thought about that after I posted it. Laughing Here ya be: scratch
Look what I'll be workin' on........ Cid__0421112137
ThndrChkn
ThndrChkn
Post  KY JELLY April 22nd 2011, 12:23 am
you could use a plate with the normal counter sunk bolts to attach it to the block and press in type studs for the transmission.
KY JELLY
KY JELLY
Post  ThndrChkn April 22nd 2011, 12:36 am
That's what I thought too. Just wanted to make sure before I start puttin' it together. Wink All things being what they should be, this thing's gonna be a bad MAMMA JAMMA!! Twisted Evil
ThndrChkn
ThndrChkn
Post  cool40 April 22nd 2011, 12:43 am
it should like rpm.keep us posted........ Very Happy
Post  ThndrChkn April 22nd 2011, 10:15 pm
cool40 wrote:it should like rpm.keep us posted........ Very Happy
Initial data indicates peak power about 9500+. Twisted Evil Cool
ThndrChkn
ThndrChkn
Post  '65 T-BOLT April 23rd 2011, 11:57 am
Pro-Stock!
'65 T-BOLT
'65 T-BOLT
Post  ThndrChkn April 23rd 2011, 12:01 pm
We need to put "this" engine in the Banana and wring it out. Twisted Evil Cool
ThndrChkn
ThndrChkn
Post  '65 T-BOLT April 23rd 2011, 12:05 pm
ThndrChkn wrote:We need to put "this" engine in the Banana and wring it out. Twisted Evil Cool
That you do!
'65 T-BOLT
'65 T-BOLT
Post  72mav April 23rd 2011, 2:47 pm
Doug,
Check those combustion chambers... Rob had to re-cut his. I guess this is a problem area. Before you deck or anything else, since they are very large to begin with.
Regards.
Al
72mav
72mav
Post  ThndrChkn April 23rd 2011, 4:01 pm
Yep. Already on that Al. Thanks for thinkin' of me there big guy. Very Happy
ThndrChkn
ThndrChkn
