D1VE block, offset ground crank
D1VE block, offset ground crank Empty D1VE block, offset ground crank
Post  thunderbolt September 6th 2009, 10:18 am
D1VE block for sale, believe still stock bore. Was used for mock up $100.00
2YABC crank offset ground to 4.142-2.20 crank pin. mains ground .010 under, snout shortend to 3.60 length
to clean up front. Never used, includes new ati sbf balancer adapter flange to use a bbf balancer-$150.00
Gary
417-886-6944
417-840-1556
thunderbolt
thunderbolt
D1VE block, offset ground crank Empty Offset ground crank
Post  557Hatch September 6th 2009, 2:31 pm
Gary, what rods will work with that offset ground crank?? You don't see that very often anymore. Thanks
557Hatch
D1VE block, offset ground crank Empty Re: D1VE block, offset ground crank
Post  thunderbolt September 6th 2009, 4:47 pm
At that time was going to use a 6.8 rod and a custom piston but don't remember compression height. But there
are several ways to build with a aftermarket rods/piston combo.
Gary
thunderbolt
thunderbolt
Post  Nevs September 6th 2009, 9:42 pm
I believe Diamond has shelf pistons that will work with that stroke and either a 6.700" or 6.800" rod. They cover many different head styles as well.
