598 A head w dyno results
+8
knrclark
Wheelie58
D. Sea
12 posters
Finally finished up my new 598 last week. Spent Friday afternoon on the dyno getting it broken in and tuned for the most part.
Ok, here we go with some results and build details.
I'm happy with it. Not bragging, but nothing to keep secret either. My goal was 1050 hp and 900 ft lbs of torque using a single cast 4V intake. Made that with some room to spare. I realize I could have made more with a nice tunnel ram intake, but that would have complicated the packaging in the car. This is not a max effort deal. Just a reliable, low maint piece. No Ti valves, no shaft rockers, no crazy valve springs, etc.
The HP flattens out after 6400, but doesn't drop. That tells me there is a airflow bottleneck. I think it's the intake. It's almost box stock. Smoothed up the casting a little about 1" into each runner and cut the clover leaf out of the top as it was an obvious restriction to my Terminator throttle body. On the first freshen up I may send the intake for some Pro porting.
Larger 721K version for if you can't read this one well:
https://2img.net/h/i374.photobucket.com/albums/oo186/dgcole01/Tbird%20engine/dynosheetC.jpg
The build:
The short block:
Ford Racing A460 block. 4.600 bore from Lem Evans
Scat 4.500 stroke 4340 crank. Adney Brown at Performance Crankshaft cut the counterweights down, knife edged them and shortened the snout to the short Boss 429 length. He balanced the crank as well.
Scat 6.800 H beam rods w ARP 2000 bolts.
Diamond mini dome pistons, Lem Evans custom spec'd
Childs and Akerly Extreme Rings
14:1 compression ratio
Clevite Main and Rod Bearings. Dura Bond "wide" cam bearings
The induction:
Trick Flow A460 18-bolt heads via Lem Evans. Ported by Charlie Evans at Evans Racing Engines. Port and valve job input From Lem Evans, Phillip Oakley and Lawes Mayfield. 2.35/1.88 SS valves.
link to head flow sheet:
https://2img.net/h/i374.photobucket.com/albums/oo186/dgcole01/Tbird%20engine/A4608X10.jpg
Trick Flow A460 cast single 4 intake.
Comp Cams custom solid roller spec'd by Lem Evams
Comp 7/16 pushrods
Crower Stainless Steel stud mount rockers, 1.73 ratio
Jomar stud girdle
Morel Ultra Pro lifters, stock .875 size
Danny Bee belt drive
NGK -9 plugs
Oiling:
Kasse oil pump
aluminum oil pan by Charlie's Pans spec'd by Lem Evans
oil system mods, thanks to David Willingham at Advanced Motorsports Engineering.
Jomar oil filter
Brad Penn 30W oil
Front dress:
ATI 917562 damper. Damper has BBC front and SBF hub, designed for Boss 429 crank snout.
.400 damper spacer by Keith Fulp Motorsports (KFM)
MSD Crank trigger, plug wires and crank trigger distributor. Used a 6AL/Blaster coil on the dyno
will use a Digital 7/HVC coil in car. 32° timing
crank pulley/trigger wheel/mandrel centering adapter by KFM
Front motor plate cut for Danny Bee by KFM
special timing Pointer for Danny Bee by KFM
Star Machine std Vac pump from James Monroe at Killer Ron's
CSR water pump
Powermaster Ultra Mini Denso style alternator
Fuel system:
Ron's Fuel Injection alcohol injection
Terminator, single 2100 cfm throttle body
Ron's #1 pump. Using idle and high speed bypass.
Thanks to James Monroe and Keith Fulp for tuning help via phone when on the dyno. The fuel is still a little rich. I'm putting an Altronics combo O2/EGT logger system in the car to fine tune it.
Machine shop services by Rick Pennington and Albert Moore at:
http://www.performancespecialtiesinc.com/
Pics to come later.
The build:
The short block:
The induction:
Comp 7/16 pushrods
Jomar stud girdle
NGK -9 plugs
Oiling:
Kasse oil pump
Jomar oil filter
Brad Penn 30W oil
Front dress:
CSR water pump
Fuel system:
Pics to come later.
Re: 598 A head w dyno results
congrats to all involved , very nice build David
Nice build Dave
Better keep it locked up next weekend, you may get a 534ci engine swapped in over night
D. Sea- Posts : 2768
Nice Bread and Butter Race Build !!!
Got it home today. It had a couple of minor oil leaks on the dyno. All fixed now.
A few pics in an album:
https://s374.photobucket.com/albums/oo186/dgcole01/Finished%20engine/
It was an honor to be involved in such a cool project. David has helped a lot with ideas and suggestions to make my little parts even better.
I can't wait to see it flying down the track.
Nice job!
Keith
Nice job!
Keith
now maybe you can make the bash! looken good
Nice
My God David that looks really nice. Great job.
Kerry
Kerry
knrclark- BBF CONTRIBUTOR
WOW. I think I'm going to follow this build for my 598 deal
Ace
Ace
powerstrokeace- Posts : 1496
powerstrokeace wrote:WOW. I think I'm going to follow this build for my 598 deal
Ace
It's been a good one so far. Happy with it. I'm sure it makes more power now than it did on the dyno via on track tuning. It's about 5 mph faster in the 1/8 now vs the tune it had on the dyno (left dyno tune on it when first put in car). Some of that was in the converter (prob 2mph) with about 3 mph in tuning on the fuel system.
Best so far NA of 5.22 @ 134, 1.15 60' at 2955 lbs. Launch at 4400, converter flashes 6250, shift at 7K, cross at 7100. Would prob have more if I leaned on it a bit, especially on the launch rpm.
It's running fine. Only plans for the off season is new valve springs and have the Morel lifters rebuilt for piece of mind.
what size tire and gear? glide? gearset?
2POWERADDERS- Posts : 51
2POWERADDERS wrote:what size tire and gear? glide? gearset?
14.5x32 tire
4.57 gear
Glide w 1.80 straight cuts
FTI 9" converter
Congrats its nice to see my car's faster twin haulin ace!
BUZZ BUZZARD- Posts : 80
» 598" ;) A head - Dyno results page 6
» Dyno results: A headed 557 on 91 octane pump gas. DYNO UPDATE page 6
» 582 tfs a460
» 598 C heads
» 533 Dyno Results
» 582 tfs a460
» 598 C heads
» 533 Dyno Results
