Gear stagger
Gear stagger
Can you run a slight stagger in a dirt drag truck? I like the stagger in my bog truck now, but the new truck will spend half of its time on top of the ground and half in a mud race pit.
FORDMUD- Posts : 290
Re: Gear stagger
I ran staggered gears in my truck for the past several years. Only issue I had wa if i had it on hard ground alot it seemed to eat ujoints faster. In the pit it kept the truck running straighter.
lghting94- Posts : 762
Re: Gear stagger
yep no problem running stagered ratio in a drag truck, try to keep it under 10% overdriven, I've ran mine at about 8% for 3 seasons with no breakage at all, mostly drags, the odd bog pass
Steve
Steve
Touch N Go- Posts : 10
Re: Gear stagger
I personally will not run a staggered gear
crittersf1- Posts : 521
» TCI Manual Without a brake-3rd Gear Flare Fixed But Now 2nd Gear Flares. Frank Merkel please help?
» Anyone using this, C6 Low Drag Gear Set with bearings, wide ratio planet gear sets?
» 29x10.5 w tire ,1.80 first gear glide, nitrous , wanting 6800-7000rpm thru traps ...what gear roughly???
» Pro Stock Trans gear ratio / Rear Gear
» 460 rotor gear connecting gear bad
