'86 Vintage C6.. Dexron or Type F?
'86 Vintage C6.. Dexron or Type F? Empty '86 Vintage C6.. Dexron or Type F?
Post  psquare75 May 3rd 2011, 9:42 pm
I have a C6 from an 86 E350 with 64K miles. As far as I can tell it's never been opened (the plastic plug was still in the pan). I replaced the filter, front and rear seals, pan gasket, and backed off the band adjustment several turns and adjusted it to spec.
Usage is just daily driver type stuff behind a very mild 460 in a 78 Cougar.
Dipstick says "Dexron II". I was going to stick with Dex/Merc. Valvoline makes a 'high mileage' fluid I used to resurrect a 15 year old trans that had 30K miles, and works great.
'86 Vintage C6.. Dexron or Type F? Maxlifed
Any reason not to, in this particular case?
psquare75
psquare75
http://www.reklessracing.net
'86 Vintage C6.. Dexron or Type F? Empty Re: '86 Vintage C6.. Dexron or Type F?
Post  Frank Merkl May 9th 2011, 11:05 am
go with type F it will firm up the shifts
Post  psquare75 May 10th 2011, 9:35 am
Thanks Frank.
psquare75
psquare75
