Quench question.
Quench question. Empty Quench question.
Post  FORDMUD May 6th 2011, 2:44 pm
Does desired quench distance change with compression? Does a 9 to 1 eninge require the same quench as a 16 to 1?
FORDMUD
FORDMUD
Quench question. Empty Re: Quench question.
Post  Paul Kane May 6th 2011, 3:34 pm
Provided you have an effective quench distance, compression ratio in-and-of-itself is not a deal changer in the quench distance.
Paul
Post  FORDMUD May 6th 2011, 4:12 pm
Short block is together piston is .017 in the hole. I would rather run a stock type gasket, mainly because of the stories I read about cometics leaking on a less than perfectly machined surface.
FORDMUD
FORDMUD
