Piston to cyl wall clearance ?
While prepping my 466 for reassembly I noticed some consistant light vertical scratches. With L2404F pistons what would be a good side clearance for a marine app ? I cannot find what TRW had recommended, so I am just double checking. I thought it was .003 - .005 and then we add .005 for the marine use. I am just not sure.
Jim
Jim
Re: Piston to cyl wall clearance ?
.010 sound awful loose for a cold running application.
Actually, this specific "cold running application" is the very reason that performance marine engines are set up loose in the cylinders: The block stays cool and does not expand while the piston sees a lot of heat from the upper rpm and does expand a lot. So you set the bores loose to accomodate the piston expansion relative to the cylinder expansion. (Especially true with #1 & #5 in a jet boat which sees the cold lake water first, set those cylinders more loose than the others.)dfree383 wrote:.010 sound awful loose for a cold running application.
That being said, 0.010" is indeed very high for your application, Jim. The L2404 base specification was just 0.002" in the instruction sheet that I last saw, and in your particular application I would think that 0.005" is plenty.
Paul
» Piston to wall clearance?
» motorpsort block sleeve thickness
» Piston to Wall Clearance For Marine App
» I need to vent Quench vs piston to wall clearance
» Anyone know how close the Forged L2366f piston is to cast 429 piston?
