Piston to wall clearance?
powerstrokeace
Guy's at what point is to much and would need pistons replacement? This is a all out N/A drag motor in a Dragster.
Ace
Ace
powerstrokeace- Posts : 1496
Re: Piston to wall clearance?
It'd depend somewhat on the skirt design/mfrs. spec. Pistons can be ran pretty loose but the life of the ring seal will be shorter.
Lem
Picking my stuff up tomorrow and the machine shop said there at .0085. There JE's with a small dome. I'll be contacting you in the very near future for the Cam. It the 555 ci we talked about a few weeks back. It has a Lunati cam right out of the book.
Ace
Ace
Call JE with the job # and ask them what the clearance spec. is. If it's .007" you aint in bad shape. One could have the skirts coated if need be.
I dont have the job# these came in the motor that came with the car we bought last year. Funny thing is that the deck of the block needed milled .004 to remove the impression from the steel ring in the head gasket. But the heads were fine? figure that one out.
Ace
Ace
A few years ago, our spare road race engine, (a 331 small block Chevy), had .014" piston to wall. It had out of the box Arias pistons and ran very well; just ate up rings rather quickly.
Of course, 60 laps with a road race engine is probably more than 100 runs drag racing.
You could always have the pistons knurled. I had a "dim bulb" machinist who honed my 347 (4.031) bore to .008 piston clearance, 'cause it's got forged pistons' . I had the pistons knurled and DID not return to the "high performance" machinist. With the knurl I was able to set my wall clearance at .0045 and it's still good after 2 seasons. It cost 4$ per piston to have it done.
ustahava67- Posts : 56
.0085 is fine.
.0085 used to be normal.
Mark O'Neal- Posts : 286
Agreed, 0.008" used to be typical. You will likely make a little more power at this clearance than you would at 0.004"-0.005". As Randy noted, it will be at the expense of ring life, but this is racing, right?Mark O'Neal wrote:.0085 is fine.
I know people that have successfully run double-digit clearances in blown alcohol engines...
Thanks Mark. I was trying to figure out when I would need to replace the pistons. This motor came with the car and has some very odd conditions on how it was built and stupid problems in my mind. I guess 4.600 bore and 4.5 stroke will be later with newer heads.
Ace
Ace
JE use to stamp the job# on the back side of the piston,turn the piston over and look just above the pin holes.
Larry T- Posts : 1076
these pistons were built in 98-99. they started doing this in 2000-20002 from what i was told.
Ace
Ace
Paul Kane wrote:Agreed, 0.008" used to be typical. You will likely make a little more power at this clearance than you would at 0.004"-0.005". As Randy noted, it will be at the expense of ring life, but this is racing, right?Mark O'Neal wrote:.0085 is fine.
Your right about not as much power with .004" clearance.....if a piston that was designed for .007' is installed with .004" the skirt may very stick to the bore.....which will soon = no power
A typical big bore A460 piston from JE or Diamond, these days, will have an installed recommended clearance of .0065"-.007". Then add clearance for power adders.
» Piston To Wall Clearance ???
» Piston to cyl wall clearance ?
» Piston to Wall Clearance For Marine App
» I need to vent Quench vs piston to wall clearance
» Anyone know how close the Forged L2366f piston is to cast 429 piston?
