what is the most hp/tq from an a460 .....
what is the most hp/tq from an a460 ..... Empty what is the most hp/tq from an a460 .....
Post  bruno May 11th 2011, 8:32 pm
"block" ....n/a of course , what was the combo ? could be any head also ....
http://WWW.CKRME.COM
what is the most hp/tq from an a460 ..... Empty Re: what is the most hp/tq from an a460 .....
Post  Lem Evans May 11th 2011, 8:35 pm
895 for tq. down this way with the TFS A460 heads.......A460 block.
Post  schmitty May 11th 2011, 9:02 pm
I think that 981 on Phillip's last engine is the most I've seen on a dyno sheet so far. One BAD dude there.
Post  David Cole May 11th 2011, 9:04 pm
Made made 920 @ 5700. 900 and above from 5300-6400
Dyno sheet:
https://s374.photobucket.com/albums/oo186/dgcole01/Finished%20engine/?action=view&current=dynosheetC.jpg
Post  richter69 May 11th 2011, 9:19 pm
have no idea what mine made................. Laughing
Post  res0rli9 May 11th 2011, 9:24 pm
richter69 wrote:have no idea what mine made................. Laughing
How much dose your time slip say it has Rolling Eyes scratch
Post  richter69 May 11th 2011, 9:28 pm
plenty
Post  cool40 May 11th 2011, 9:38 pm
more than a 540bbc? Laughing
Post  Larry Williams May 11th 2011, 10:18 pm
who makes a 540bbc? singer?
Larry Williams
Larry Williams
Post  Larry Williams May 11th 2011, 10:19 pm
895/1072
Larry Williams
Larry Williams
Post  bruno May 12th 2011, 4:45 pm
Larry Williams wrote:895/1072
very nice #'s Larry ...... are those with a-heads ? and what cubes ?
Post  Larry Williams May 12th 2011, 5:09 pm
598 with a heads. phil did the motor you have seen pictures of it.
Larry Williams
Larry Williams
Post  richter69 May 12th 2011, 5:50 pm
Q16?
Post  bruno May 12th 2011, 5:59 pm
David Cole wrote:Made made 920 @ 5700. 900 and above from 5300-6400
Dyno sheet:
so you had 920/1069 on alky ...correct ? how much was done to those heads ?
Post  David Cole May 12th 2011, 6:27 pm
Dyno sheet:
Yes, injected alky with just M1. Single 4V intake. Intake unported other than clover leaf removed. Charlie and Lawes hand ported the heads. No CNC work. Charlie's valve job with input from Lem and Phillip. This is with 2.35/1.88 SS valves. Hope to put larger Ti valves in down the road so I can advantage of some steeper valve job angles for better flow.
Post  Larry Williams May 12th 2011, 7:05 pm
Q16?
yes Q 16
Larry Williams
Larry Williams
Post  bruno May 13th 2011, 8:36 am
so how many builds are out there with c-heads and a a460 block ? seems like the a460/a460 is the more common build .....
Post  dfree383 May 13th 2011, 8:41 am
Not at all bruno, C's on A460 Blocks are very common. A460 heads are just a little more user friendly.
