Engine plate questions
I am putting BBF in 1984 mustang, it will be a street car. If I use a front engine plate and normal pulley driven water pump, what water pump you guys use so the pulleys line up. Also how do you mount the power steering and alternator? Any pics would help.
tiger- Posts : 272
Re: Engine plate questions
are you gonna use a midplate also?
This engine plate stuff will be new to me, so no I won't use mid plate unless it is neede with front plate. I was planning on using stock trans crossmember. I will get some of the braces that keep the engine from moving.
Motor will be in the 700 hp range is the reason I was thinking engine plate.
tiger- Posts : 272
if your not going to do a midplate I would just stick with the factory mounts, much easier to pull all the accessory stuff on as well.
Thanks, just wasn't sure if engine mounts would take that power.
tiger- Posts : 272
» Cam thrust plate and water pump baking plate questions
» C9VE engine from 69 Continental -- Have questions about where to go with this engine
» Engine Vacuum and Tune Questions
» bore plate questions
» Putting together an engine with what I have laying around. Have some questions.
