Roller Cam Bearings Install Cost
Roller Cam Bearings Install Cost Empty Roller Cam Bearings Install Cost
Post  tompietwo June 6th 2011, 7:35 pm
Machine shop working on my block says that the no. 4 cam bore is about .001 off centerline. Also says that the ID is about in the middle of the tolerance. He suggest grinding down the no. 4 cam journal .0005 (cheap fix) or installing roller cam bearings. Anyone have an opinion on this? Also, what is the going rate on machining a block and installing roller cam bearing?
Need some fast responses...need to give him an answer in the morning to keep my place in line.
Thanks,
tompietwo
Roller Cam Bearings Install Cost Empty Re: Roller Cam Bearings Install Cost
Post  Lem Evans June 6th 2011, 7:43 pm
Hone the cam tunnel to the high side and install the wide/extra clearance cam bearings.......polish the journals a little as needed.
Post  Wheelie58 June 6th 2011, 7:47 pm
$450 to bore and hone the cam tunnel here in GA.
Call me if you need more detail.
Thanks,
Keith
678-458-2033
Wheelie58
Wheelie58
Post  tompietwo June 6th 2011, 8:02 pm
Lem,
Thanks for the suggestion...I sent you a PM.
tompietwo
Post  rmcomprandy June 6th 2011, 8:33 pm
Dura-Bond offers a .005" oversize O.D. cam bearing set #FP-30R
For an easy fix, have all the bores line honed to a +.005" dimension and use the over-sized O.D. set.
Personally, for a single thou, I'd run it as the oil clearance is suppose to be more than that.
