roller cam bearings
JBR-3
litshoot
ChrisH
roller cam bearings Empty roller cam bearings
Post  ChrisH April 14th 2019, 1:59 pm
i decided to try roller cam bearing. I didn't need them, but figured for the heck of it I would try them. these are in a motorsport block by the way.
I installed them the first time after getting the block back form he machine shop and they were too tight. re-machined the block and now when the cam is in if you give it a flick at the snout it will spin 2 revolutions. I can also slide 0.001 feeler between the journal and the roller bearings all the way around.
here is the problems.
1. when sliding the cam in, the first three journals go in fine. when the fourth journal is fully inserted it gets tight going through the bores. Same thing when I am sliding the final journal in. when the cam is about 5/8" from being all the way in it gets tight again. once it reaches full insertion it is fine again. The journals are 0.0002 - 0.0003 under high side spec. so while they are on the bigger side they are within spec.
2. when the cam is fully in the bores and turned it walks back 1/8" . once I put the gear on the front this stops the walking, but you can feel it load and unload a little against the bronze cam retainer.
my first thought was the cam was bent slightly. however, it's run-out was 0.0005. that seems ok.
I know the cam bores were cut and honed on a proper mandrel but my question is does this sound like a bore is cut crooked? or basically the five bores are not perfectly aligned?
I also tried this:
1. removed bearing three, inserted the cam. Everything was "fine" (the tightness upon insertion was gone)
2. put three back in, removed four, inserted the cam. everything was "fine" (the tightness upon insertion was gone).
so my questions are:
1. if this is not correct, what is crooked and what is the best way to check it?
2. since it turns free and has proper clearance can this be ran like this? my real concern is the desire to walk backwards . BTW, this is a roller cam. forgot to mention this.
like I said in the beginning, I brought his on myself by wanting to try roller bearings. my biggest problem is trouble shooting information is limited on roller bearings like these so if someone has some insight it would be appreciated.
thank you
chris
ChrisH
roller cam bearings Empty Re: roller cam bearings
Post  litshoot April 14th 2019, 10:58 pm
What happens if you put bearing 3 or 4 in the first or 2 journal
litshoot
Post  ChrisH April 15th 2019, 12:09 am
no change. I also had another set of bearings, no change.
I got a 7/16 fine thread bolt to properly bolt the cam gear on and off course that stopped all walking. it also feels even on the turning pressure. I don't have a proper torque wrench to measure and watch inch lbs variation. if I didn't know about the two spots of assemble tightness I would look at the feeler gauge clearance and how well it spins and think there are no problems.
ChrisH
Post  c.evans April 15th 2019, 1:56 am
Are you pulling the roller cam bearings in, or driving them in? I would not be taking the bearings in and out this many times, you will lose crush on the shell. I made my own mandrels and I pull them in very gently. The cam bearing has a side with lettering and numbers, it is thicker and stronger than the other side. Only drive or pull on the side of the bearing with the numbers. I suspect the bearing holes in the block are not truly lined up or on center with each other.
Hope this helps, Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Lem Evans April 15th 2019, 10:22 am
.0005" run out is as good as it's going to get.
The journals being under the high side dia. so, you should be good there too.
Sounds weird but, does it act the same if you install the cam from the rear of the engine?
Post  ChrisH April 15th 2019, 8:11 pm
Charlie,
thanks for the heads up. I do drive them in. I had thought about pulling them in, but hadn't spent the time to build the jig yet. And yes, if I get this solved I will install a fresh set of bearings for reasons you mentioned.
Lem,
I had not thought of that. there is certainly something to be learned in that exercise. you get so brain locked on doing something a certain way (like cams load from the front) that occasionally you miss something.
ultimately I know this is in the block. its just a matter of which journals and exactly what is wrong (misalignment or the bore hole being "cocked"). then there is the little matter of fixing it.
thanks for the ideas.
chris Harrington
ChrisH
Post  ChrisH April 15th 2019, 8:13 pm
still waiting for someone to tell this is no big deal. it'll run for ever like this. Wink
ChrisH
Post  JBR-3 April 15th 2019, 10:32 pm
Last edited by JBR-3 on October 17th 2020, 2:56 pm; edited 1 time in total (Reason for editing : .)
JBR-3
Post  10.0 April 16th 2019, 3:23 am
If the bearings still have a press fit and cam spins nice, then I wouldn't worry.
I used needle cams bearings over a few times, just mark which hole they came out of.
Always drive them in from the lettering side[It's thicker]
I had a solid collet made for my cam bearing installer, easiest part of the whole shortblock was the needle cam bearings.
10.0
Post  litshoot April 16th 2019, 9:01 am
was it honed with deck plates, and you have heads off or vice versa. it shifts with the heads on?
litshoot
Post  ChrisH April 16th 2019, 9:31 am
i think i found the culprit, bore three.
my bore gauge isnt long enough to properly measure this bore so i had to use snap gauges. installing the cam from the rear like lem mentioned shed a little light light on things. went back and measured bore three again and believe i found the issue. i need to find a longer bore gauge or an extension for mine to confirm. but it looks like that bore could still be a little tight. i wont be able to say for sure until i get a proper bore gauge length.
thank you for the help everyone.
ChrisH
Post  Lem Evans April 16th 2019, 9:10 pm
You may be better off replacing the bearings that have been 'crushed' more than once.
Post  ChrisH April 16th 2019, 9:50 pm
yeh, when I have it resolved I will install new bearings. $50 worth of bearings aren't worth a motor.
ChrisH
roller cam bearings Empty passing on a something i found helpful
Post  ChrisH April 21st 2019, 11:06 pm
for anyone that is having trouble with cam fitment and has bore gauge limitations or roller bearing don't allow the use of one.
it hit me to just cut the end off an old cam, one journal and a couple lobes for a handle. this lets you feel, fit, test one bearing at a time.
its a free test and can give an idea about fit for individual journals. if they feel good then you know its a bent cam, or an alignment problem between bores.
by the way, even oem cams are fairly hard.
ChrisH
Post  Lem Evans April 22nd 2019, 10:46 am
Good thinking.
Post  Mark Miller April 22nd 2019, 11:08 pm
Lem Evans wrote:Good thinking.
X2!! Smile
roller cam bearings Empty Pin them in
Post  FDB May 18th 2019, 12:59 am
I think the needles get alittle crossed up and don't straighten out until loaded.  At any rate if you decide to run it I would tap bolts in though the valley, on both sides the bearings and just short of the journal diameter, so the shell can't walk out.  Seen this happen on BBC.
FDB
Post  CDMBill May 20th 2019, 1:04 pm
Once you have these right I think you are going to like having them. I've built two engines with the roller cam bearings. We were careful with install and cam bore spec. That said the first set are still working perfectly in an IDT Premier block that we first built in 2006. e other set are in a Ford Motorsport A460 block.
CDMBill
