ROLLER CAM BEARINGS ?
ROLLER CAM BEARINGS ? Empty ROLLER CAM BEARINGS ?
Post  Wayne Pearce October 18th 2019, 9:37 am
Hey, guy's:
I have a 460 block with rollerized cam bearings in it, the current cam is a Comp Cams XR292R mechanical roller. I'm contemplating converting it to a hydraulic roller set up - will this work with the rolllerized cam bearings?
Wayne (SAWDOFF) Pearce
Wayne Pearce
ROLLER CAM BEARINGS ? Empty Re: ROLLER CAM BEARINGS ?
Post  lance flake October 18th 2019, 10:32 am
I think as long as you stay with a steel cam core you will be fine.
lance flake
Post  Wayne Pearce October 18th 2019, 11:21 am
Are all hydraulic roller cams cores steel? Sorry if this is a dumb question, but it's going to be a fairly expensive switch and I don't want to throw my money away on a bad choice.
Wayne Pearce
Post  rmcomprandy October 18th 2019, 11:50 am
Wayne Pearce wrote:Are all hydraulic roller cams cores steel?  Sorry if this is a dumb question, but it's going to be a fairly expensive switch and I don't want to throw my money away on a bad choice.
NO ... even a few solid roller cams will vary.
Nitrided ductile iron or complete Austempered ductile iron or induction hardened lobe SADI cast steel cores are very commonplace with hydraulic roller camshafts.
They certainly can and will be made of billet steel if one wants to pay the extra price; some already are.
Post  stanger68 October 18th 2019, 8:20 pm
What would the harm be in just swapping the lifters and leaving the solid lift cam?
Post  Wayne Pearce October 18th 2019, 9:49 pm
Will that work? I would think that the spring pressures might be a bit stiff for hydraulic lifters. This engine was built ten years ago, and I don't remember what springs are in it, what ever Comp Cams recommended for the XR292R cam.
Wayne Pearce
Post  c.evans October 22nd 2019, 12:10 am
Well either way, if the valve springs have been in it for 10 years, it's time to change valve springs. Yes, you will need a softer / milder valve springs for hydraulic roller lifters. Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  stanger68 October 22nd 2019, 8:34 am
I’ve never personally done it. Heard tale of it being done. I was hoping one of the pros would weigh in and either confirm or deny the plausibility. I was told you could put hydraulic roller lifters on a solid cam but not the other way around. Seems believable, if you put the two beside each other they’re not that much difference in the shape. Now if the solid cam were a very radical race grind then I may not be so quick to try it.
Post  rmcomprandy October 22nd 2019, 10:17 am
stanger68 wrote:I’ve never personally done it. Heard tale of it being done. I was hoping one of the pros would weigh in and either confirm or deny the plausibility. I was told you could put hydraulic roller lifters on a solid cam but not the other way around. Seems believable, if you put the two beside each other they’re not that much difference in the shape. Now if the solid cam were a very radical race grind then I may not be so quick to try it.
I can say that a lot of competitors in the Engine Masters Competition for different years have used hydraulic roller lifters on "tight lash" solid roller cams. It was a slight performance downgrade however, that type lifter was the rules.
Post  Wayne Pearce October 22nd 2019, 11:30 am
Thanks, everybody for your replies. One last question, aren't the hydraulic roller lifters taller than the mechanical roller lifters causing increased angularity in the push rods?
Wayne Pearce
Post  rmcomprandy October 22nd 2019, 10:12 pm
Wayne Pearce wrote:Thanks, everybody for your replies. One last question, aren't the hydraulic roller lifters taller than the mechanical roller lifters causing increased angularity in the push rods?
YES ... by about .625" higher pushrod cup.
Post  Wayne Pearce October 23rd 2019, 9:47 am
Thanks, Randy. I'm by no means a mechanical engineer, but has anybody ever approached the idea of a "low profile" hydraulic roller lifter to negate the acute push rod angle? In my "simple" mind, it seems like a simple fix.
Wayne Pearce
Post  rmcomprandy October 23rd 2019, 10:59 am
Wayne Pearce wrote:Thanks, Randy.  I'm by no means a mechanical engineer, but has anybody ever approached the idea of a "low profile" hydraulic roller lifter to negate the acute push rod angle?  In my "simple" mind, it seems like a simple fix.
There is really no way to do that and still have a working hydraulic piston mechanism within the lifter.
Maybe it could be shortened by .200" or so, but that is not worth the expense for any company to spend a lot of money designing and producing something which will work well hydraulically; and still be taller than a solid.
Part of the hydraulic cavity within the lifter body is already lost to the space where the upper side of the roller wheel needs to displace.
Post  Wayne Pearce October 23rd 2019, 12:47 pm
Thanks, Randy. I couldn't ask for a better explanation. Can you tell me if it's a worthwhile expenditure to do the conversion? The engine was originally built for a Pro Street 50 Ford Coupe. Now it resides in a 60 Starliner that's built to be a "cruiser", not a bad ass pro streeter. The engine is pretty mismatched for the car, but it's all I had.
Wayne
Wayne Pearce
Post  rmcomprandy October 23rd 2019, 4:08 pm
Wayne Pearce wrote:Thanks, Randy.  I couldn't ask for a better explanation.  Can you tell me if it's a worthwhile expenditure to do the conversion?  The engine was originally built for a Pro Street 50 Ford Coupe. Now it resides in a 60 Starliner that's built to be a "cruiser", not a bad ass pro streeter.  The engine is pretty mismatched for the car, but it's all I had.
  Wayne
Not with any type stud mounted rocker arm system unless it is very temporary.
They work OK with "Bolt Down" or "shaft mounting".
Post  Wayne Pearce October 25th 2019, 10:10 am
Sorry, Randy - but your last statement left me a bit confused (not unusual). Are you saying stud mounted rockers are not preferred for a hydraulic roller cam set up?
Wayne
Wayne Pearce
Post  rmcomprandy October 25th 2019, 10:50 am
Wayne Pearce wrote:Sorry, Randy - but your last statement left me a bit confused (not unusual).  Are you saying stud mounted rockers are not preferred for a hydraulic roller cam set up?
  Wayne
YES, studs are NOT preferred.; neither "rail rockers" or those using guide plates.
