cam bearings install
torkair
95lightiningguy
new2460
cam bearings install Empty cam bearings install
Post  new2460 August 15th 2010, 9:51 pm
how hard would it be to put my own cam brgs in? anybody ever done it? would i need a special tool to do it? thanks
new2460
cam bearings install Empty Re: cam bearings install
Post  95lightiningguy August 15th 2010, 10:05 pm
You will need this tool to do it http://www.summitracing.com/parts/PRO-66820/ . I spend the money to let someone else do it but I have done it in the past its not that hard.
95lightiningguy
95lightiningguy
Post  69F100 August 15th 2010, 10:19 pm
not that hard with the cam tool you just got to make sure you keep the holes in the bearing lined up with the holes in the block and not to over tighten the tool on the bearings
Post  torkair August 16th 2010, 12:03 pm
If you feel that you're gonna be doing a lot of cam bearings yourself go ahead and get the bearing installation tool, otherwise I'd spend the money getting my block cleaned and having the bearings installed for me.
torkair
torkair
Post  IDT-572 August 16th 2010, 1:47 pm
Better to pull them in, than knock them in.............
Post  bbf-falcon August 16th 2010, 2:20 pm
I use to do my own until my brother loaned my tool out and forgot who he loaned it too.The hardest one is the last one (Front) Make sure it's in straight. Smile But,My machinist is one of my sponsors so I let him do them for me. Smile
Post  chuck stevens August 16th 2010, 9:28 pm
I've got two cam bearing tools. One for knocking out the nastys, the other...CLEAN, for the new ones.
chuck stevens
http://E-MAIL= stevensracingent@aol.com
Post  jbozzelle August 17th 2010, 2:35 pm
Blake, How do you "pull" them in?
Also, the front one should be done through the rear of the block, right? I just picked up a new tool for cheap and plan to do my own.
Post  IDT-572 August 17th 2010, 2:45 pm
Threaded rod , Lem got it for me several years ago............ Pucks to match the bearings and also to fit the block bores
Post  jbozzelle August 17th 2010, 2:53 pm
Does the puck tighten up on the bearing or just sit inside of it with a lip on the edge to hold it so you can pull it in?
What should I look for once I pound in the new ones? Just make sure the cam spins free?
Post  IDT-572 August 17th 2010, 3:07 pm
jbozzelle wrote:Does the puck tighten up on the bearing or just sit inside of it with a lip on the edge to hold it so you can pull it in?
Yes, it fits just like the knock in type, but is easier on the bearings. You could mic the cam bearing bore against the cam journal to see the oil clearence. If it spins good and free they usually work good.
The bearings that you get from Lem and Randy M. are all number one Cleveland cam bearings. They are a touch wider and are close to .001 bigger on the i.d.
Post  jbozzelle August 17th 2010, 4:37 pm
Thanks. I got them from Lem. Just need to order the cam in a few weeks and I'll be good to go!
