New PB 10.47@133 545ci 3900lb Aussie Falcon GT 12/06/16
+19
gmsmkr
Coupe Devil
norg
DFI429
Gregaust
pro64
Dave C.
quick 52
darren
whitefield
droppedf100
johndickjr
psfracer
bbcoupe
23 posters
Page 1 of 3
Page 1 of 3 • 1, 2, 3
Just got back from a weekend of racing at Heathcote (Australia)
Results were good with a best of 10.91 @ 130.5mph!
https://www.youtube.com/watch?v=VC4SOPDWAtw
Factory 460 block (ARP stud kit top and bottom, mains stud girdle)
Scat 4.5in stroker crank
6.8in Eagle H-beam rods
Probe pistons (part no.12397-030 and have a dish of 18.5cc)
Comp cams XR292R roller cam
Blue thunder aluminium heads (chev exhaust)
Edelbrock Victor manifold
Pro Systems SV-1 1100cfm
MSD 6AL2 Digital, MSD Crank Trigger
Edelbrock aluminium water pump
Try-Y headers (2in primary and 2-1/4 secondary into 3in collector)
Car/driver weighs about 3900lbs
res0rli9- BBF CONTRIBUTOR
Re: New PB 10.47@133 545ci 3900lb Aussie Falcon GT 12/06/16
Awesome. With that mph I am sure you can get mid 10s out of it. Weird seeing the steering wheel on that side......
sweet looking ride !
how do you like that carb
johndickjr- Posts : 896
johndickjr wrote:how do you like that carb
Love the SV-1, ran it as it came straight from Patrick.
Nice pass. I've followed your car for a long time on 460ford. That's a lot of mph for the et too. What stall is the converter? Im sure some juice will pick up a ton out of the hole. I can't wait to build motor like that to move my 4100 truck
droppedf100- Posts : 176
Was more happier with the MPH than the E/T. Still running a 3000 stall built for my 460. This run was done on a back up pump, my old holley blue, as I was having pressure probs with my Magnafuel.
sweet car and nice pass.!
whitefield- Posts : 2244
what the video..look at it when he hit the gas its a delay till the car moves..neat to see that
A quick update.
Just ran a new PB of 10.82 @ 120mph. Slow mph as it was during eliminations and I backed off the throttle for a win.
Here is a video from the drag meet (it's a long one). I ran in a small bracket with friends of a mate who passed away last year for a trophy in his honour. His car was being run by a close friend who bought it from the family, it's the Gold 1967 Falcon GT, 347ci windsor with a Procharger and jerico 4spd.
Big Block Fords that featured were,
Orange Falcon GT Coupe 545ci N/A (mine)
Light Blue Falcon Coupe 429ci with NOS
Red Falcon 4door 557ci N/A
https://youtu.be/gGWieyhHkSo
You've got some tuff street cars down there,
darren- Posts : 64
sweeeeeeet with that mph you got mid 10s in it for sure
quick 52- Posts : 612
Been back to the track(unfortunately only once a year) and attacked things a little differently this time. Ran set up straight from the street as I cruise on the weekends(air cleaner, full exhaust, street radials). Ran 10.86@126 and won the final of the bracket.
https://www.youtube.com/watch?v=tKI9jsCffvk
How do you like the CalTracs ?
Dave C.- Posts : 1268
Hard to say. I put them on (they were sitting in a mates shed doing nothing) and set them up as per instructions and went racing. Car seemed to launch the same as it did with previous set up. Aussie Falcon GT's came with factory radius rods which were giving similar lift/traction.Dave C. wrote:How do you like the CalTracs ?
I didn't have time to make any adjustments, and I haven't run the car with only springs alone.
This is with the radius rods.
Nice car. Part mustang and part Torino!
cam
hey nice car sounds great . i was wondering if your still running that same camxr 292,if so how do you like it.
pro64- Posts : 57
Thanks pro64. The cam does a good job, haven't had any other roller before. Car sees more cruising and day trips than the track and performs well on the street. Originally had 3.5:1 gears but cruising revs were a bit low so now runs smoother with 3.89's.pro64 wrote:hey nice car sounds great . i was wondering if your still running that same camxr 292,if so how do you like it.
10.91 falcon
i have installed that cam in my present build,502 p51 heads 1150 dominator . dropping that in a 64 comet. will be used mostly on the street so what your telling me sounds like good streetability and good track too judging by your 10.91 at 3900 lbs. im thinking im going to be around 3400 lbs that should get me closer to my goal uv a 9.90 streetcar. any way enough of my yapping peace....
pro64- Posts : 57
Sounds nice, being 500lbs lighter should help you heaps.pro64 wrote:i have installed that cam in my present build,502 p51 heads 1150 dominator . dropping that in a 64 comet. will be used mostly on the street so what your telling me sounds like good streetability and good track too judging by your 10.91 at 3900 lbs. im thinking im going to be around 3400 lbs that should get me closer to my goal uv a 9.90 streetcar. any way enough of my yapping peace....
I keep an eye on the roller lifters and will soon have another set to do change overs with in between rebuilds.
Pro64, I'd be surprised if you didn't like the XR292R . It works nice
Gregaust- Posts : 625
» PLEASE POST PICS OF YOUR ENGINES !!
» Twin Turbo 604ci Falcon coupe shows up at Aussie cruise!
» Aussie 65 w/BBF
» Another Aussie
» Another Aussie thats been here a while.
» Aussie 65 w/BBF
» Another Aussie
Page 1 of 3
