crankcase pressure
crankcase pressure Empty crankcase pressure
Post  Larry Williams June 22nd 2011, 12:13 pm
my engine (sbf) has excessive crankcase pressure. I have ordered a moroso pump Etc.
my question is Does excessive pressure have an effect on oil pressure? Is the pressure caused my high compression or un seated rings?
I am replacing the rings with total seal gapless as well.
Larry Williams
Larry Williams
crankcase pressure Empty Re: crankcase pressure
Post  richter69 June 22nd 2011, 1:04 pm
A vacuum pump is a good idea but its not a fix for leaky rings. I'd stay away from the gapless stuff.
Warm up the engine and do a leakdown test..............
Post  whatbumper June 22nd 2011, 7:13 pm
I would just re-hone the cylinders and change the rings. I never use gapless stuff either.
