Cutting spring seats/guides & portmatching pictures
nuclearcobra
its taking longer than i thought but there coming out ok these are my old heads i sold to my buddy for his motor i'm building for him,there ported c8ve-e castings off a 429 i didn't do the porting even tho i have to do a victor portmatch because they were matched to a stealth before.
nuclearcobra- BBF CONTRIBUTOR
Re: Cutting spring seats/guides & portmatching pictures
Good job there HeRo...................
Nice side by side comparo.
cletus66- Posts : 865
Good job. I rmember the first time I ever did that was on my first 429, and I did it with a hand drill.
Hey, it worked!
Hey, it worked!
Scott Foxwell- Posts : 419
Yea thats what i'm using my cordless ridgid drill i have 3 more seats and 15 more valve guide bosses to do and now i can see why i need a drill press bad
I've done a set with a 1/2" drill. Worked great. A drill press would be a pain in the butt to set up to match the valve angles... Not even sure you even could with a typical drill press.
BigBlockRanger- Posts : 1267
I was wondering about the valve angles on a drill press and if you can get it to spin slow enough. When you guys did it by hand how long did it take and how hard did you bare down on it ? these have never been cut so theres a lot of material to remove on the seat taking out that step, the one valve guide boss i did go's a lot faster than the seats. Do you just press enough to make a fine dust which takes forever(over an hour each, the seats i mean) or do you press harder to make little tootsie rolls which will cut it down in about 20-25 minutes ? this is my first time doing it and didn't know how easy it is to ruin the cutter ? i'm only spinning it about 50 rpms.
When I done my doves took me about 4 afternoons after work working on them 2 to 3 hours each day.I push down just hard enough to make little tootsie rolls and checking to make sure I didn't cut to deep.The checking part is what took me so long making sure I didn;t go to deep.The guiles do go alot faster my cutters are the ones comp cams sale.
Jim
Jim
Ok then its normal to take a while thanks, and i'm just removing the step for a dual spring package and cutting the guide boss down for pc seals and higer lift cam. The ones i bought are howards cams.
Finaly done cuttin seats/guides
now i got 4 more holes to port match and the new valves and hardware can go in.
» Affect of valve spring install height on spring rating..
» spring cups or spring isolators?
» C460 valve guides
» C460 valve guides
» c9ve heads complete, guides and seat seem in good shape, $175
» C460 valve guides
» C460 valve guides
