v8 springs in fox with stock 460
v8 springs in fox with stock 460 Empty v8 springs in fox with stock 460
Post  Travis460 July 24th 2011, 9:45 am
Is there anyone running v8 springs with iron headed 460. In a track only fox? This only a strip car do I need to just go to coilovers right away, or can I use 90/10's and v8 springs and be fine. Motor is stock with a proform 750 weiand stealth and headers. Stock converter (for now) and 3.73 gears. Anyone have any issues with this setup?
Travis460
v8 springs in fox with stock 460 Empty Re: v8 springs in fox with stock 460
Post  Travis460 July 24th 2011, 11:31 pm
Anyone? Did everyone quit running 460's in mustangs? J/' but awaiting some help. Will this thing transfer weight properly with v8 springs or should I save my pennies and buy a coilover kit?
Travis
Travis460
Post  Mark Miller July 25th 2011, 1:05 am
I think you'll be fine with the 5.0 springs and the Cast Iron heads.I still have 4 cylinder springs on the front of my 89 Mustang with a BBF but i have Aluminum heads.
Later Mark.
Post  dfree383 July 28th 2011, 7:26 am
it will work fine.
Post  Travis460 July 28th 2011, 2:41 pm
what kind of 60 footers are you guys pullin with the v8 springs???
thanks
Travis
Travis460
Post  8liter July 28th 2011, 3:17 pm
What are you expecting....? I think you rear suspension/tires are gonna make the biggest difference in 60' times. I ran stock v8 springs and had 1.6 60's
8liter
8liter
Post  dfree383 July 28th 2011, 3:54 pm
I don;t remember the 60ft times but the 1/4 mile ETs where well into the 10's
Post  Travis460 July 28th 2011, 9:41 pm
I just want the thing to hook and be consistant. As far as the rear strange adjustable shocks fixed upper and lowe control arms and stock springs. I just didn't know with that heavy engine if the stock springd would allow for proper weight transfer.what do you guys use for transmission mount ? I pulled this engine and c6 trans out of a motor home. I have heard there is 2 different length transmissions.
Travis460
