1980-96 f100/150 manual steering?
 1980-96  f100/150 manual steering? Empty 1980-96 f100/150 manual steering?
Post  f250mike July 28th 2011, 9:07 pm
What years and models should I be looking for?
I removed my pump but still have the power gearbox. The steering is somewhat tight at low speed and I don't like it.
I'm about ready to hit the junkyards for a manual box and would like to narrow down my search.
Mike
f250mike
f250mike
 1980-96  f100/150 manual steering? Empty Re: 1980-96 f100/150 manual steering?
Post  Copperhead July 28th 2011, 9:27 pm
Mike,
The steering box itself isn't that hard to fine (Auto-Zone or Advance can get them),........it's the pitman arm that's nearly impossible to locate. The splines are different on the manual versions.
IIRC,.....a Ranger pitman arm (manual of course) will also fit.
FWIW,.....
If you can't find one, I have a dropped/raised manual pitman arm with the correct spline count. It should be fairly easy to mdify it so it would work.
Copperhead
Copperhead
Post  f250mike July 28th 2011, 11:28 pm
Thanks Keith
I didn't know about the different splines on the manual box.
I'll try to find a manual box and pitman arm in a yard. At least that way I'll have a core and the right arm.
f250mike
f250mike
Post  ThndrChkn July 29th 2011, 12:10 am
Hey Mike. I got one from a wrecking yard from a Ranger. '83 I believe. The pitman arm that came with the box from the Ranger fit right on my truck. I sold mine to Jones when I changed my truck to the Foxbody front end. You might check and see if he still has it since he sold his truck...
ThndrChkn
ThndrChkn
