start and run 10-20 seconds then die
Barney
plowboy34
86 F250 460, stock ignition system, as said starts right up and runs fine for 10-20 seconds then just shuts off. Pulled in garage one night running just fine then next morning this happened....any thoughts
plowboy34- Posts : 223
Re: start and run 10-20 seconds then die
Fuel pump ,water in filter and carb or filter clogged check and make sure you are getting gas.if you getting gas check your ing coil
don't believe it's fuel cause it will fire right back up. just dies in a few seconds. Somebody told me there was a oil pressure switch that if it showed no oil pressure it would shut off the fuel pumps....is this true. I didn't think a carbed engine would have this.
That's got the old square electronic ignition box on the the inner fender. It's probably the problem if it does have it
56Tbird- BBF CONTRIBUTOR
56Tbird wrote:That's got the old square electronic ignition box on the the inner fender. It's probably the problem if it does have it
Yea,I had one in the shop that did the same. I have one here(used) if you need it. (FREE)
Not the ignition box, put in a new one and does exact same thing. Well at least I have a spare now..... . So dang hot just don't feel like messing with it....believe it is so hot here the Devil went back to hell to cool off.
Check the ing coil had the same thing happen to my 69 F100 yes it has the electronic box the blue one had the same thing happen to me one time.Put a new box on it same thing fire up and go dead or then it might run until I touch the gas go dead changed the dizzy same thing so I decided to change the coil fired up ran like a top.I would have never figured it was the coil because most of the time the coil will not fire when it bad but this one would fire until it fired up.
Jim
X2 on the heat was heading to the track but the heat here is well like you said heat index right now at 107*
Jim
simple test do you have a test light ? if not get one . hook test light to good ground and probe terminals at coil with key on both should light up brightly, crank engine over with test light probing negative side of coil should pulse if not you have a bad pickup in distibutor, if no light on negative side of coil before cranking bad coil.
maverick532- Posts : 181
Well the fix was the oil pressure safety switch that shuts off the fuel pump in case of no oil pressure. Installed a new one and it's all good....thanks for the help guys
» My little 302 won't start
» I got my 15 seconds of fame
» Hero....to zero...in 9.5 seconds
» Starter kick back
» 460 Won't start when Hot....
» Starter kick back
