new mini starter power master 9405
new mini starter power master 9405  Empty new mini starter power master 9405
Post  fastford600 August 7th 2011, 8:09 pm
the starter i have is a 9405 . new in box just my back up starter the plate that bolts to the bell housing has a few scratches on it i used the new plate on my new motor because it was shiney . the plate that is on there is just fine and not a thing wrong with it . it has never had any power put on it ........ this starter sells for 300... so ....210 shipped in the usa. call 910 840 7226
Powermaster 9405 Ultratorque Ford 351M 460 Mini Starter
Brand: POWERMASTER
Manufacturer's Part Number: 9405
Condition: New
Powermaster #9405 Starter, Ultra Torque, Mini, Ford, 351M/400/429/460.
P66-9405
Description:
These Ultra Torque starters from Powermaster live up to their name by delivering 250+ ft.-lbs. of torque. They feature a 4.4:1 gear reduction ratio, and cranking power for engines with over 18:1 compression. These 10.5 lb. starters have a machined aluminum adjustable mounting block, work with oversized kickout oil pans, and are water and corrosion-resistant.
Specifications:
Brand:
Powermaster
Product Line:
Powermaster Ultra Torque Starters
Part Type:
Starters
Part Number:
P66-9405
Starter Style:
Mini
Starter Finish:
Natural
Starter Rotation:
Standard
Maximum Recommended Compression Ratio:
18.0:1
Gear Reduction Ratio:
4.40:1
Mounting Block Material:
Cast aluminum
fastford600
fastford600
