Well the 712's going together!!!
+24
strokedmyford
nuclearcobra
NO FAIR
NOS42
Ranch71460
John I.
bigblockfox468
psfracer
'65 T-BOLT
whitefield
Wayne Pearce
Barney
56Tbird
28 posters
Page 1 of 4 1, 2, 3, 4  Next
Well the 712's going together!!! Empty Well the 712's going together!!!
Post  Frank Merkl August 12th 2011, 1:49 am
Started the final work on it Tuesday morning , the block is an 1987 vintage AR aluminium 11.200 deck block with 4 -4 bolt main caps(steel)rear is only 2bolt , a new 5.300 stroke Bryant billet crank , Venolia Aluminum 7.190 long rods , Venoilia pistons 4.625 bore custom built , an old set of well raced A441 BOSS heads, and a Kaase designed 1" lift cam , + 4 -maybe 5 nitrous kits!!!!and a C6. Expected ET in my 2800 lb '93 Mustang Door car 6.7's -6.8's @ 215-220 mph!!!!!!! I hate to jinx the project but I plan on racing this motor on the August 27- 28 weekend!!!!!and the dyno is booked for the motor aug 22- 25
Well the 712's going together!!! Boss007-8
Well the 712's going together!!! Boss008-6
took a full day after the cylinders were bored and honed of clearancing to get the 5.300 arm with aluminum rods to clear the bottom of the cylinders and the pan rail , the crank and rods and pistons were in and out today and we have the .050" min every were!!!
Talking about theft , here's the sign in my shop!
Well the 712's going together!!! Boss003-13
Well the 712's going together!!! Empty Re: Well the 712's going together!!!
Post  res0rli9 August 12th 2011, 2:13 am
Cool Cool
and
Cool Cool Cool for the sign, my kinda thanking Smile
Post  Frank Merkl August 12th 2011, 2:46 am
up here, Canadian Tire sells an alarm system that calls me on my cell ( gives me time to load the rifle) $65 with 1 motion sensor all wireless and addtional sensors are $20 with a 1000 ft range from the base and Walmart sells a great little pressure washer for less that $100 (1400 psi) and it works great for cleaning up stains on the concrete!!!!
Post  res0rli9 August 12th 2011, 3:03 am
Frank Merkl wrote:up here, Canadian Tire sells an alarm system that calls me on my cell ( gives me time to load the rifle) $65 with 1 motion sensor all wireless and addtional sensors are $20 with a 1000 ft range from the base and Walmart sells a great little pressure washer for less that $100 (1400 psi) and it works great for cleaning up stains on the concrete!!!!
Will that alarm work in the states.
down here we have gators to get rid of left overs Smile
Keith
Post  bruno August 12th 2011, 9:31 am
not much grinding on the block for that stroke ??
http://WWW.CKRME.COM
Post  dfree383 August 12th 2011, 9:45 am
Damn Frank that thing is going to be bad azz!!
Post  Frank Merkl August 12th 2011, 10:42 am
Bruno, only took the better part of a day grinding to get the rods to rotate threw , the crank was in and out 27 times!!
Post  schmitty August 12th 2011, 11:51 am
Looks like it's coming together nicely Frank. BTW the valve body and trans brake were working good up in Sturgis. Very Happy
Post  56Tbird August 12th 2011, 1:18 pm
Frank ,that's gonna be some kinda WILD Ride!! Good Luck with it!!
56Tbird
56Tbird
Post  Barney August 12th 2011, 2:27 pm
FANCY!!!!
Barney
Barney
Post  Frank Merkl August 13th 2011, 9:04 am
Pic of the clearancing needed
Well the 712's going together!!! Boss004-15
and pic of the pistons Venolia designed for me with an extra strengthening band in the shirt for heavy load nitrous
Well the 712's going together!!! Boss003-14
Post  Frank Merkl August 14th 2011, 1:56 am
buttoned up the short block tonight , good thing I had a set of -.001 ,std & +.001 rods and mains on the shelf and have a lath as the comp cam journals were .002 larger than any of my crane cams ( and their a bitch to polish down) she's set at .003" on the rods and mains with .008 for endplay, .008 on the pistons to bore , and .0025 on the cam journals
Well the 712's going together!!! Boss008-7
Well the 712's going together!!! Boss006-11
Well the 712's going together!!! Boss005-16
Post  Wayne Pearce August 14th 2011, 8:44 am
Frank: That small base circle cam is about the skinniest cam I've ever seen (LOL)! Is that required due to the big arm on your stroker crank? That's gonna be one nasty mofo, I can't wait to see the dyno numbers!
Wayne (SAWDOFF) Pearce
Wayne Pearce
Post  schmitty August 14th 2011, 11:26 am
Wayne Pearce wrote:Frank: That small base circle cam is about the skinniest cam I've ever seen (LOL)! Is that required due to the big arm on your stroker crank? That's gonna be one nasty mofo, I can't wait to see the dyno numbers!
Small base circle for getting that 1" of lift. I have a .965 lift cam that has no base circle also. Cool
Post  Mike R August 14th 2011, 11:38 am
Damn Frank, it sure is pretty!!!
Post  cool40 August 14th 2011, 12:04 pm
Cool i like big motors! and mustangs! i wish i was your neighbor,you'd hate it tho. Laughing
Post  Frank Merkl August 15th 2011, 7:52 pm
the beasts taking shape !!!
Well the 712's going together!!! Boss001-14
Well the 712's going together!!! Boss002-17
oil pan needs a starter pocket welded in it , intake needs to be welded back together, plumb the dry sump, plumb the fuel & the nitrous , build a set of headers ! shit, I better get off the computer and get back to work as this thing is suppose to be on the dyno next monday morning!!! good thing there's 24 hrs in a day
Post  Mike R August 15th 2011, 8:16 pm
Shocked Shocked Shocked Shocked Shocked
Post  whitefield August 15th 2011, 10:40 pm
Frank that is on bad ass motor? Shocked Shocked Shocked Shocked Shocked Shocked Shocked
whitefield
whitefield
Post  res0rli9 August 15th 2011, 11:16 pm
ooooooooooh ya nice Cool
Post  '65 T-BOLT August 15th 2011, 11:46 pm
Looks as if that thing will lay down some good numbers! Hope the stangs chassis can handle it! LOL! How many stages of laughing gas?...3? Frank is Cool
'65 T-BOLT
'65 T-BOLT
Post  Frank Merkl August 15th 2011, 11:57 pm
Whitefield , it better be BAD ASS as I'm sending it out to do battle with some light weight bickle cars with 814 &818 inch Sonny's Chevy Hemi motors , there N/A and running 6.60's @207 and we're going to spray lots!! 3-4 kits maybe 5 !!!
Post  56Tbird August 16th 2011, 1:05 am
That's totally Awesome .....WOW Factor is gonna peg the meter when you turn all NOS solenoids loose on it!! affraid cheers king
56Tbird
56Tbird
Post  psfracer August 16th 2011, 2:15 am
WOW this is crazy...............in a good way of course. Its coming together fast.
psfracer
psfracer
http://www.psfracer.com
Post  Frank Merkl August 16th 2011, 5:27 am
Jon Kaase and his crew ie Roger have helped a lot on this build !! Talked to Jon 2 years ago on this build ,He Designed the cam , got Venolia to build the (as ever motor I've run has had venolia rods & pistons )rods and pistons and the pistons and ring package, looks perfect!!
