Carb Problems
+11
the1969fordguyinky
crittersf1
racnrick
waypastcrazy
fattboy123456
15 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Carb Problems
his engine is running in the standard rotation ... not backwardsthe1969fordguyinky wrote:Reading this is sounds like the engine was running in reverse rotation? Can you really do that?
DanH- Posts : 1081
Re: Carb Problems
DanH wrote:his engine is running in the standard rotation ... not backwardsthe1969fordguyinky wrote:Reading this is sounds like the engine was running in reverse rotation? Can you really do that?
But, with the wrong starter it would have been trying to run backwards
crittersf1- Posts : 521
Re: Carb Problems
slopoke76 wrote:that is correct, and can crank that way.
And if everything else is correct (cam, dizzy gear, etc...) can, and will, run backwards. Counter rotating engines are the norm in twin engine boats. Sometimes it's done in the gearbox, but usually the engines are counter rotating...
jbozzelle- Posts : 3705
Re: Carb Problems
Yep I have a boat that has a 351 reverse rotation engine. Only thing different for the most part is the dizzy and starter. It will run in the normal rotation but really really really bad.
slopoke76- Posts : 7
Re: Carb Problems
Ok this thread has gotten confusing. The engine doesn't turn backwards. The starter is mounted on the opposite side of the bellhousing so it must turn the opposite direction compared to the regular starter but the 3.8l, 5.0l 460 or whatever turns the same way as it did in the car you just took it out of.
jasonf- BBF CONTRIBUTOR
Re: Carb Problems
While the OPs engine may not rotate backwards there are in fact counter rotating engines used in boats. Since this is a single engine deal it's probably standard rotation.
The starters are moved up top to keep them out of the bilges.
Re: Carb Problems
jasonf wrote:Ok this thread has gotten confusing. The engine doesn't turn backwards. The starter is mounted on the opposite side of the bellhousing so it must turn the opposite direction compared to the regular starter but the 3.8l, 5.0l 460 or whatever turns the same way as it did in the car you just took it out of.
fattboy123456 wrote:Right the reason being that my starter was located in the back of the bell housing not in the standard location under the exhaust ports
What I read is the starter goes in the rear of the bell housing and that would make a regular start turn the engine backwards
Re: Carb Problems
I can tell ya some do turn in reverse. I happen to own one. You can watch the dizzy and tell.
Page 2 of 2 • 1, 2
Page 2 of 2
