Intake Height
Tore
Intake Height
How much taller is Victor Intake over a Stealth?
Thanks Tore
Thanks Tore
Tore- Posts : 865
Re: Intake Height
go to there web sites and they tell ya the ht. on each one
res0rli9- BBF CONTRIBUTOR
Re: Intake Height
stealth is 5.25 front and 6.75 rear and the victor is 6.30 f/r
Re: Intake Height
Are you sure its not 6.25 on the front not 5.25?
SLord82- Posts : 145
Re: Intake Height
SLord82 wrote:Are you sure its not 6.25 on the front not 5.25?
click on the one your looking at and it'll tell you the ht.
http://www.holley.com/types/Ford%20Big%20Block.asp
Re: Intake Height
•High Rise Dual Plane Design
•Square Carburetor Mounting Flange
•No EGR provisions
•Power band: Idle-6800 RPM
•Height: Front 5.25", Rear 6.75"
•Port Size: 2.15” height 1.89" width
Re: Intake Height
I think your right thats an inch and a half front to rear difference, probably a typo..........
Re: Intake Height
IDT-572 wrote:SLord82 wrote:Are you sure its not 6.25 on the front not 5.25?
Soeery guys , i just had went to the site to look at the measurements
Re: Intake Height
http://www.holley.com/8021.asp
Re: Intake Height
Just measured my Stealth.
front= 5 5/16... rear= 6 5/8
Re: Intake Height
res0rli9 wrote:SLord82 wrote:Are you sure its not 6.25 on the front not 5.25?
You guys know that those measurements are taken at the front and rear china rails, right...?
A straight edge on the carb pad, then measure the distance from the china rail. Those aren't actual carb pad measurements.
Re: Intake Height
rmcomprandy wrote:res0rli9 wrote:SLord82 wrote:Are you sure its not 6.25 on the front not 5.25?
did not know Randy , thanks for clearing that up
Re: Intake Height
Yes, add the front and rear and divide by 2= carb pad HT.....They can do the math I gave them the actual measurements
Please Note: To figure ( carb pad height ) add front and rear dimensions and divide by 2
Re: Intake Height
There is betwenn 1/4 and 1/2 in difference between the two intakes victor being the taller.
lghting94- Posts : 762
» Intake height
» Eliminator Big V Intake Vs KFM Custom Trick Flow A460 single Dominator Intake
» lowest intake manifold pad height
» Tunnel Rams for the Street??
» New style A460 Intake vs. Mafia height pics
