Bed Lift for my trailer
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Bed Lift for my trailer
any up dates ???
res0rli9- BBF CONTRIBUTOR
I did some tweaks to the last upper beam today and spent the afternoon painting it. I put the posts up tonight and just need to finish up the bed part and add one more pulley tomorrow. Once I get it done I will post some more pics.
Here is everything getting painted. Not too exciting. lol
jasonf- BBF CONTRIBUTOR
Here a few more project pictures.
The passenger side.
ATV winch.
Pulleys for passenger side.
Here you can see the lower bar is raised up while I was testing.
ATV winch.
The drivers side is up as well.
I made the cables tonight.
I just need to add a pulley on the passenger side to tie all the cables to the same winch.
Looking good.
Had to make a few changes today. The winch was pulling to much on the post so I moved it to the upper beam.
Hear it is bed down.
Here it is bed up.
It is probably around 6'2" so I can just walk under it. I originally planned on using two winches and no cables side to side so I am going to add some tubing across the back by the cables so it doesn't pull the back corner post out of the wall. I am sure there will be a few other tweaks as well.
Here it is bed up.
looks like it should work great !!!
Frank Merkl- Posts : 1524
Page 2 of 2 • 1, 2
» Will Miller mid lift rockers 1.8 be good for a solid roller 272 Dur. .688 lift?
» 4 inch lift on a 79 f-150
» lift kit, diesel vs, 460
» Kasse P 51 heads
» Cam duration @.200" lift
» Kasse P 51 heads
Page 2 of 2
