rod bolts??
Larry Williams
racinghabbit
rod bolts??
I just purchased a new set of rods eagle crs67003d and i am wondering if they are strong enough for my iron headed 545 race engine????14:1 compression.. shooting for 600+ hp.....
eagle says there good to 800hp
what do you think?
what do you think?
racinghabbit- Posts : 575
Re: rod bolts??
i just broke an eagle rod bolt at 700 hp
Larry Williams- Posts : 884
Re: rod bolts??
600hp is pretty lame from a 545" motor with 14:1 compression.......... You mean 800+?
The ARP 2000 rod bolts are a worth while upgrade to them.
Re: rod bolts??
right away calling my motor lame!!!!
its going to be about 600 yes, due to some rules that hold me back from makeing more power...
thanks guys...
thanks guys...
Re: rod bolts??
Well it is !!!!
Whats the Rules? What Class?
Re: rod bolts??
Exhaust manifolds? Stock Intake? Carb Rule? How Much Vac? What Fuel? What Heads? Cams allowed?
Re: rod bolts??
I ran stock Eagle rods with the bolts they come with for over two years, countless dyno runs Two oop's to 8150 rpms and never had a problem 861 hp shifting at 7100..................
You will be alright
You will be alright
Re: rod bolts??
i feel that a correctly stretched bolt is as important to life as the bolt you use, overstretch the best rod bolt and failure is likely to happen
cooter- Posts : 220
Re: rod bolts??
I ran an eagle rod in my prior combo never had an issue always ck'd the stretch of the bolt per eagles instuctions , you should be ok .
maverick532- Posts : 181
Re: rod bolts??
I ran um in my 472 no problem, mid 9 sec deal in a 3200# car.
Re: rod bolts??
will a number of retorques have a bad effect on them?
Re: rod bolts??
retorque is suppost to be ok if they were never overtorqued but i figure a set of bolts at freshen time cant be a bad investment if your pushin the hp
cooter- Posts : 220
Re: rod bolts??
Larry Williams wrote:will a number of retorques have a bad effect on them?
That depends upon how much the overall free length of the bolt grows from original length with no torque applied. Each bolt has a spec for that however, not many people log their original length to begin with, lol.
Re: rod bolts??
rmcomprandy wrote:Larry Williams wrote:will a number of retorques have a bad effect on them?
that was my problem no original records for length.
