Drilling and tapping a phenollic carb spacer?
NO FAIR
Drilling and tapping a phenollic carb spacer? Empty Drilling and tapping a phenollic carb spacer?
Post  NO FAIR September 4th 2011, 3:46 pm
Has anybody drilled and tapped a phenollic carb spacer with any luck or is an aluminum carb spacer the better option. Need to tap a carb spacer for PCV and vac modulator.
Dave
Smile
NO FAIR
NO FAIR
Drilling and tapping a phenollic carb spacer? Empty Re: Drilling and tapping a phenollic carb spacer?
Post  rmcomprandy September 4th 2011, 3:52 pm
NO FAIR wrote:Has anybody drilled and tapped a phenollic carb spacer with any luck or is an aluminum carb spacer the better option. Need to tap a carb spacer for PCV and vac modulator.
Dave
Smile
Drilling YES ... press the tube for vacuum into the spacer after drilling to the correct size for light press.
Post  NO FAIR September 4th 2011, 3:56 pm
Dave
Smile
THX!
Dave
Cool
NO FAIR
NO FAIR
Post  richter69 September 4th 2011, 4:10 pm
as stated yes you can .
Post  c.evans September 4th 2011, 4:33 pm
For some reason, that stuff cuts better and cleaner if it's really cold. Throw it in the freezer overnight, and then drill it undersize for your press fit tube.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Doug Rahn September 4th 2011, 5:38 pm
Like the others have said, you can drill and tap it. And Charlies suggestion about freezing it first works real good. Phenolic material is some wonderful stuff, we still use it on the aircraft at work for control cable pulleys, and hydraulic line support/clamp blocks.
Drilling and tapping a phenollic carb spacer? Pulley%20Group%202-web
Post  David Willingham September 4th 2011, 7:02 pm
Sure does make a mess in a CNC though....
David Willingham
David Willingham
Post  Lem Evans September 4th 2011, 7:08 pm
David Willingham wrote:Sure does make a mess in a CNC though....
Yep....I've been to the Jomar shop where the powercones are made. Smile
Post  rmcomprandy September 4th 2011, 7:20 pm
JOMAR has to have the best vacuum/separator system for machining that stuff that I've ever seen.
Post  Lem Evans September 4th 2011, 7:31 pm
Agreed.
Post  NO FAIR September 4th 2011, 9:29 pm
c.evans wrote:For some reason, that stuff cuts better and cleaner if it's really cold. Throw it in the freezer overnight, and then drill it undersize for your press fit tube.
Charlie
Great idea thanks for the tip.
Dave
Smile
NO FAIR
NO FAIR
Drilling and tapping a phenollic carb spacer? Empty WE HELICOIL THEM TOO.....
Post  jpb6061 September 7th 2011, 3:30 pm
The phenolic oval track adapters we make are drilled, tapped, and helicoiled.... We've sold thousands and I don't recall any complaints... I'm sure you could overtorque a stud or bolt and rip the helicoil out. Some day I'll try it with a torque wrench and post the results!
JB
jpb6061
