carb screens
+6
342g
Wheelie58
10 posters
carb screens
http://intensityracingproducts.com/sportmanseriesscreens/4500screens.html
I found these and I though I would share with you guys....
the Coug- Posts : 3055
Re: carb screens
An interesting idea for a drag car that's not running an air filter considering how dirty/rocky/trashy some track's pits & return roads are.
DILLIGASDAVE- Posts : 2262
Re: carb screens
Thats what I was thinking Dave, beats getting a rock from the burn out box thrown down your carb....
Re: carb screens
Nice looking products. That domed one looks a lot like the kitchen strainer that (as I recall) David Cole told us about a few months ago.
Re: carb screens
Wheelie58 wrote:Nice looking products. That domed one looks a lot like the kitchen strainer that (as I recall) David Cole told us about a few months ago.
I agree but some of us have lower scoop so I was looking at the lower flat type....migh get one and have the KY boys test it on the dyno see if it looses hp?
Re: carb screens
I have one of the flat ones, But I have to cut my air pan bigger, to fit over it, the guys that sell these are racers from Ohio, nice folks.
342g- BBF CONTRIBUTOR
Re: carb screens
Here is what Keith was talking about. I did this prob 8 yrs ago on my first dragster. Worked great. About $6 stainless kitchen strainer. Cut the handle off, couple of bolts and some silicone to hold it on. There have them in several sizes, so a 4150 or 4500 is covered. It is stiff enough to not get sucked in, but is still flexible enough that you can flatten it out for scoop clearance. I also like that the mesh is finer, it can keep smaller rocks out.
Re: carb screens
I have made several like David posted above, very cheap and very effective. I'm sure the premade ones are nice, but if you have any fab skilz at all you will save some coin............
Re: carb screens
the screen does look finer so that is probably what I will do also.....
Re: carb screens
Be kinda neat if someone did a cfm airflow test to see how much restriction that fine mesh screen produces.
83-88T-Bird Guy- Posts : 1003
Re: carb screens
The wire mesh when shaped in a dome creates a tornato type vortex and increases the the air flow a million times,,,,,,,,,,,,,,,OH never mind I think I saw that on TV.
airford1- Posts : 192
Re: carb screens
83-88T-Bird Guy wrote:Be kinda neat if someone did a cfm airflow test to see how much restriction that fine mesh screen produces.
Ive run with a screen, no screen, and with my 6" k&n with a std and a filter top.....................no et or mph difference whatsoever..................the sealed airpan is worth about .5 mph though.
The screen will keep out the rocks but we still have some dust to deal with..........no way I;ll run without the filter set up.
Re: carb screens
I tried one these a few weeks ago. http://www.jegs.com/i/Edelbrock/350/1002/10002/-1?parentProductId=743329
With the foam element I couldn't even do a burnout in the box. The engine would cough,sputter and die.
I made a few 1/4 mile passes with just the base and screen and my trucks ET was off.
After a short cool down I made another pass with just the open carb. I picked up a tenth.
In all I made 5 passes with the open carb and my ET was exactly the same for all 5. A tenth quicker than with the base and screen.
The top of my carb is 3" from the hood with no scoop. I can't see the large mesh screen causing a flow restriction. My guess is the base caused some bad turbulence.
f250mike- Posts : 628
Re: carb screens
f250mike wrote:I tried one these a few weeks ago. http://www.jegs.com/i/Edelbrock/350/1002/10002/-1?parentProductId=743329
Back in the day those were sooooo cool looking however they didn't work very well. A friend of mine encountered a backfire and the foam caught on fire
D. Sea- Posts : 2768
Re: carb screens
might as well throw a red rag over the carb, I am like Damon those are useless been there done that, kind of like the foam in the velocity stacks.......
» weiand carb adapter 4500 carb flange to 4150 intake
» Gas carb v/s Alky carb
» to big a carb or not
» To big of carb?
» help me set my carb up!
» To big of carb?
