my build ....not 100% done but take a look predictions any help would be greatly appreciated
88 mustang lx
full cm cage cert to 8.50s with thru floor frame connectors 2x3
mini tubbed
tube k member and motor plates with qa1 coil overs up front
glide with 1.80 straight cut gear with transbrake
engine in(process) of building
521
d1ve block
main studs
head studs
filled to bottom of freeze plugs
je 12.1 compresssion pistons with scat h beam rods and a 4.3 crank from scat also
dove c heads ported have no #s but look to be done legit has bigger 2.250 valves
ported vic intake with a 1050 dommy
have a crosssbar plate for applied nitrous ....want to spray 200-250 shot can do anything from 150 to 400 in my kit with the tune up sheets
still need to get a converter and a camshaft to my combo with n20 solid roller of course
car should way 3000lbs with me in it ...not a street car this car i bought as a roller has been 8.60s with a sbf so its now mild lol
looking to run 9.50 index class ...........any ideas on hp and times this thing may run or how much n20 to use to reach my goals ......with put up dyno sheets when engine is done ,, any help or info is always greatly appreciated ...andrew
mini tubbed
521
d1ve block
main studs
head studs
5pointslow- Posts : 1408
Re: my build ....not 100% done but take a look predictions any help would be greatly appreciated
I ran a similar combo, but 460 inches, and big shot plat. went 8.78 so your goal is very achievable.
im kinda curious how the dove heads will react with the nitrous hope its not a wall and im limited ...prob will be .....
i was tossing the idea of i should of just bought p51 and did it n/a
doves work well with nos,and if their ported good all the better
BOSS 429- Posts : 2372
If your trying to go mid 9s you will be more than fine.
any idea what kind of power this thing should make and .....what does this combo prob run on all motor before spray ? i have no idea i just wanna run in our 9.50 index class ..........my kit goes from 150-400 nitrous shots
I know of a stock suspension 508 D0VE headed deal that runs mid-high 9s NA and runs in the 8s on spray so you 521 SHOULD have no issues running similar.
» Tunnel ram vs single carb.......pros and cons ......any help would be appreciated
» 460 build w/p51 heads build HELP!!
» E4OD build reccomendations for a 79 f150... first transmission build, no ideah what I'm doing
