whats your opinion on these rod bearings...
plowboy34
sbc...whats going on here?
138- Posts : 1593
Re: whats your opinion on these rod bearings...
not an engine analysis but it looks to be a super dirty environment or there was way to much sandpaper involved it that build ......is that a hint of green oil and to much teeth
Is that a skim of rust on the crank journals? If so, that would explain the chewed bearings!!
Bill
Bill
billandlori- Posts : 2081
Dirty environment or ran without oil for short times but often.
Not to be harsh but if it was put together with the crank looking like that the mechanic is the problem.....just sayin
plowboy34- Posts : 223
From the looks of the crank and rod looks to me it was ran with water in the oil and let it sit with it in it or put to gether with in the rain bear steel and water don't mix.Yes I agree if the crank and rods had rust before being put together it is the builder folt it looks this way.
bruno wrote:not an engine analysis but it looks to be a super dirty environment or there was way to much sandpaper involved it that build ......is that a hint of green oil and to much teeth
green oil and teeth? Must be a fabio build.
Looking at the oiling holes that it must have developed in the motor. Correct me if I am wrong but won't the oiling holes be rusted if it was rusted before the install?
thanks for the replies...any this is not my motor, but suposidly the crank was polished and looked fine before it was installed ... my first thought was not changing the oil very often and condensation build up inside the motor over time... the owner said the cam and lifters looked perfect, but I didn't get a chance to see them myself so....whatever on that. but the discoloration on the crank looks like brass/bearing material to me not rust.
138- Posts : 1593
rmcomprandy wrote:Dirty environment or ran without oil for short times but often.
this seems dead on....and would make sense if it was an oiling issue, which could very well be...especially with periodic (but often) start ups and shutting it down.
138- Posts : 1593
138 wrote:rmcomprandy wrote:Dirty environment or ran without oil for short times but often.
..... or losing oil pressure, on the brakes at the end of a pass.
BigDave65- Posts : 567
BigDave65 wrote:138 wrote:rmcomprandy wrote:Dirty environment or ran without oil for short times but often.
that would make sense, but this set up has been mostly street driven. hes throwing in a new scat cast crank and new bearings... for his sake I just hope he has it machined and balanced buy someone who knows what the fuk they're doing and its assembled correctly... but by the same token he keeps tellin me "we can build that BBF ourselves and you're just wasting 3000 grand on machining, assembly, and dyno time"... I'm like 3000 grand aint shit to make sure that my 20 some grand stays together, and runs right off the get...anyway thanks for all the replies.
138- Posts : 1593
IMHO it looks like oil starvation like Randy said, with some very dirty oil. What looks like rust appears to me to be just very dirty oil also contaminated with water. In this one photo it looks like magnetized metal filings stuck to the crank, or maybe it's just lint .
» whats your opinion on this ???
» Choice on VC's .... Whats your opinion????
» My Build !!!!
» Whats up with LP?????
» whats everyone doing for the 4th ?
» My Build !!!!
