valve clearance
Larry Williams
valve clearance Empty valve clearance
Post  Larry Williams September 24th 2011, 5:51 pm
i have .090 exhaust and .092 intake valve to piston clearance. Is this acceptable in a race only motor? I feel its a little tight. The motor will go to 7500. Do I need to disassemble and rebalance?
Larry Williams
Larry Williams
valve clearance Empty Re: valve clearance
Post  Curt September 24th 2011, 5:58 pm
I'd run it with steel rods, green oil, shaft rockers and alcohol.
Post  Lem Evans September 24th 2011, 6:02 pm
I'm not sure I'd rebalance but, I'd be looking for more exh. clearance. Is this the SBF deal?
Post  Larry Williams September 24th 2011, 6:27 pm
Lem Evans wrote:I'm not sure I'd rebalance but, I'd be looking for more exh. clearance. Is this the SBF deal?
yes its the small block. I am working on the motor for next year should I source a cutter to use with a cylinder head?
h beam rods 15.5 to 1 shaft rockers green oil and alky lol
I have the big block car almost finished. just the wiring to complete. Then I trip south.
only 1 race left around here for this year.
Larry Williams
Larry Williams
Post  Larry Williams September 24th 2011, 8:39 pm
would a .010 thicker head gasket do? the pistons are .010 down in the hole now
Larry Williams
Larry Williams
Post  Lem Evans September 24th 2011, 8:44 pm
I'm not sure it'd ..."do" but it'd be .010" you did not have before.
Post  cool40 September 24th 2011, 11:59 pm
are you checking v/c with valve lash or without? how are you checking?
Post  Larry Williams September 25th 2011, 12:04 am
with the valves lashed at comp's specs
Larry Williams
Larry Williams
Post  cool40 September 25th 2011, 12:13 am
Larry Williams wrote:with the valves lashed at comp's specs
ok,so that was an idea. Laughing
Post  dfree383 September 25th 2011, 12:36 am
I will live IMO at the .092 as long as you don't float anything and your valve springs are good.
Post  c.evans September 25th 2011, 1:03 am
Larry,
I'd suggest that you Not put a thicker head gaskets on it. Like Lem, I am only concerned about your exhaust valve to piston clearance. The intake is good to go. I'd like to see around .105 to .110" clearance there on the exhaust. So,,,, either advance your cam some, (which will open up your ex. to piston clearance) or R&R the pistons and cut a little deeper exhaust valve relief in the piston. The weight of the alum. material that you'll be removing is flyshit, so do not even worry about rebalancing. Besides that, many engine builders overbalance engines all the time.
Charlie Evans
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Larry Williams September 25th 2011, 8:09 am
c.evans wrote:Larry,
Charlie Evans
Thanks Charlie. Comp calls for 106 lobe center this cam is installed at 105.5 I think I will take your advice and remove the pistons again and have them cut.
Larry Williams
Larry Williams
Post  rmcomprandy September 25th 2011, 12:35 pm
I'd advance the cam a degree ... maybe 2.
Post  cool40 September 25th 2011, 12:36 pm
Charlie Evans
i'm sure you already know this but even after you cut the pistons be sure and check v/c a few * +and- so you'll know what kinda room you have to play with later on if you want to move the cam any. Very Happy
Post  Larry Williams September 25th 2011, 8:00 pm
very good idea ty
Charlie Evans
Larry Williams
Larry Williams
