Why must a solid roller cam have lash?
+16
moparman
jason
Larry Williams
DaveMcLain
redneckprofessor
DanH
Greg_P
chuck stevens
the1969fordguyinky
20 posters
Page 2 of 2 Previous  1, 2
Why must a solid roller cam have lash? - Page 2 Empty Re: Why must a solid roller cam have lash?
Post  c.evans September 20th 2009, 10:16 am
dfree383 wrote:Like Lem has said lash can be used as atuning tool and a way to see what canim a motor likes, looser lash = slightly smaller lobe, tighter lash = slishtle larger lobe. Good rule of thumb is no less than .006-.008 or no more than .035-.040. For most cams when your expermenting
Boy! Did somebody get drunk on magaritas last night? Because they sure as heck, can't spell "sheeit", this morning! Twisted Evil Twisted Evil Laughing Razz
Uncle Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  bbf-falcon September 20th 2009, 10:28 am
Hay CharleeWere knot skloars weergeerheds Laughing Laughing
Post  dfree383 September 20th 2009, 10:45 am
Uncle Charlie
Bla!!! This coming from the "OG" that's running late the breakfast!!! Laughing
Post  Lem Evans September 20th 2009, 11:15 am
"Bla!!! This coming from the "OG" that's running late the breakfast!!!"
Charlie can't be late for breakfast....he's on duty for breakfast 20 hrs a day .
Post  rmcomprandy September 20th 2009, 11:23 am
The simple fact is that it is in the design of the "take-up" ramp and lobe flank characteristics on that particular cam lobe profile; (most common race lobe ramps are at .017" but there are many at different heights, both more and less. Lash is normally to be SOMEWHERE on that constant "take-up" ramp). They can be designed with VERY little ramp height however...
A wider/longer design lash ramp on a cam lobe profile can impart a SLIGHTLY greater contact velocity upon the lifter with a flat tappet; (acceleration is already higher than a roller cam lobe). And, SLIGHTLY more acceleration can be achieved with a roller lobe; (contact acceleration is limited more than with a flat tappet). Hollow ground flanks with a roller lobe can only gain back so much as lobe to roller angularity becomes a problem.
Unfortunately, getting a "happy" dynamic valve train and making horsepower differ in what they need.
Post  ThndrChkn September 25th 2009, 9:43 am
Very good topic, and answers... I have found through T&T, that my 521 likes a bit tighter lash... I set my lash cold then check it hot, and like Jon said, with my aluminum heads it grows right around .004... My combo likes it at .012 cold and it ends up around .016 hot...
Doug... Cool
ThndrChkn
ThndrChkn
Post  DaveMcLain September 25th 2009, 11:36 am
Messing with the lash can sometimes be a great fine tuning tool. It allows you to make the cam a little bigger or a little smaller on intake, exhaust or both.
How much it changes when the engine warms up really depends on the engine and what type of heads it has or the block material. I believe that the engines that Jon Kaase builds end up with negative lash when the engine is cold just because the great big aluminum block and heads grow so much as they come up to operating temperature. It would seem that this would make the engine impossible to start cold but I would say that because the engine is so large and the compression ratio is quite high that it's not a problem.
DaveMcLain
