general advice about an engine i broke in and built
+8
cooter
racinghabbit
12 posters
general advice about an engine i broke in and built Empty general advice about an engine i broke in and built
Post  racinghabbit October 6th 2011, 2:54 pm
a couple months ago i built a pontiac 455 engine, it runs great. BUT! it burns a lot of oil. 1qt for every 200 mi.
had all the machine work done at a good shop, new rings, new forge pistons. streeet engine about 400 hp..
I did a compression check last nite and its between 150-160 on all cyl.
I am thinking the rings didn't seat(seal).
plugs show burning oil carbon, and there is only 1200mi on them.
during break in the motor did get up to 240 degrees and we shut it down. that was around 12 min into it.
what do you guys think happened?
general advice about an engine i broke in and built Therons455build006
racinghabbit
racinghabbit
general advice about an engine i broke in and built Empty Re: general advice about an engine i broke in and built
Post  racinghabbit October 6th 2011, 2:56 pm
general advice about an engine i broke in and built Therons455build007
racinghabbit
racinghabbit
Post  jbozzelle October 6th 2011, 3:23 pm
What kind of rings? Was the finish hone correct for the rings?
Post  whatbumper October 6th 2011, 4:21 pm
the cylinder finish sure looks shiny to me. maybe too smooth?
Post  bbf-falcon October 6th 2011, 8:29 pm
When you installed the rings,Did you make sure the top/second ring ends were spaced 180* and not lined up?
Post  richter69 October 6th 2011, 8:41 pm
do a leakdown on it.
Post  cooter October 6th 2011, 9:54 pm
does the engine smoke all the time or just on acceleration or deceleration? Could be a valve guide or seal problem. You dont have a piston with the oil ring around the wrist pin do you?
cooter
Post  BOSS 429 October 6th 2011, 10:12 pm
WERE THESE FILE fit rings?
do a leak down
Post  racinghabbit October 6th 2011, 10:49 pm
just seal pro moly rings... nothing fancy.. i didnt tear it apart yet
racinghabbit
racinghabbit
Post  Frank Merkl October 6th 2011, 11:29 pm
trust me , put a new set of rings in it and don't hone it !!cylinder walls look great , a new set of moly rings will seal the first time you make it work!!!
Post  cooter October 7th 2011, 7:51 am
It is unusual to have moly rings not seat so make sure to find the fault so it doesnt happen again. How did you break it in? Do all cylinders show fouled plugs or just one?
cooter
Post  whatbumper October 7th 2011, 8:17 am
I'm with Frank. Put new rings in it and call it good.
I was unsure on the finish from my phone pics but on my home computer they look fine. We run stainless rings so finish is very important to us as well as proper breakin.
Post  racinghabbit October 7th 2011, 12:06 pm
4 cyl are showing burning oil. the other 4 are perfect and they are mixed from side to side...
broke it in at 2000rpm... but shut if donw at 12min due to heat at about 140 degreese... then waited a while and did a nother 10 min at 190 degree
racinghabbit
racinghabbit
Post  racinghabbit October 7th 2011, 12:13 pm
general advice about an engine i broke in and built Therons455build009
racinghabbit
racinghabbit
Post  IDT-572 October 7th 2011, 1:10 pm
Might want to check your intake gaskets, they may be pulling oil on the bottom into the port.
Post  StickBBF October 8th 2011, 9:49 am
What type/brand/weight of motor oil did you use to break it in with and are currently feeding it?
StickBBF confused
StickBBF
Post  dfree383 October 8th 2011, 10:15 am
Check the PVC also.
Post  racinghabbit October 8th 2011, 3:16 pm
VR1 10w30 , during break-in and still useing it
racinghabbit
racinghabbit
Post  StickBBF October 8th 2011, 10:43 pm
racinghabbit wrote:VR1 10w30 , during break-in and still useing it
Hmmmmm,,,, That may be part or all of the problem. Shocked
I've been told to NEVER use a synthetic oil to break-in an engine - only AFTER the initial break-in period would I switch to a synthetic oil.
Synthetic is just too good at lubricating that it won't allow the piston rings to seat and seal properly.
Maybe all you need to do is change the motor oil and run it some more..... or would the cylinder walls need to be de-glazed at this point?
StickBBF cat
StickBBF
Post  the Coug October 8th 2011, 10:46 pm
Syn oil will not let rings seat ask IDT572 he had to rering his cuz he put the syn in to early....
Post  bbf-falcon October 8th 2011, 11:47 pm
VR1 is not syn.
Post  StickBBF October 9th 2011, 8:12 am
How many oils are called VR1?
http://www.valvoline.com/products/consumer-products/motor-oil/racing-motor-oil/8
StickBBF confused
StickBBF
Post  bbf-falcon October 9th 2011, 7:09 pm
http://www.valvoline.com/products/consumer-products/motor-oil/racing-motor-oil/6/
Post  IDT-572 October 10th 2011, 9:33 am
StickBBF wrote:How many oils are called VR1?
StickBBF confused
If this is truly what you broke it in on, that very well maybe your problem.
Post  racinghabbit October 11th 2011, 1:02 am
i used valvoline VV211 to break it in
racinghabbit
racinghabbit
