throwing belts
strokedmyford
bigblok2000ranger
1fatcat
throwing belts
i have been having a problem throwing off my alt. belt at a high rpm, 6500 ? maybe when shift its a early 70s lower righthand alt. mount ,no pwr st.... just alt and water pump i have heard that the Cj style alt. pully was deeper and larger diameter ? have evan thought about a serpintine belt conversion any suggestions
1fatcat- Posts : 44
Re: throwing belts
Bad belt, bad pulley, misalignment of pulleys, incorrect tension, can all cause these problems. I'm running a March crank pulley on my engine, and it's been over 7200 and haven't tossed a belt yet.
schmitty- Posts : 4538
Re: throwing belts
I had to go with a Moroso 5 inch pulley on my alternator until I went to underdrive pulleys even with perfect alignment and high price belts it would throw belts over 6500. No problems with the underdrive set-up now.
Re: throwing belts
If everything the other guys told you is good then buy a dayco belt there v-belts are far superoir than anyone else.
strokedmyford- Posts : 126
Re: throwing belts
strokedmyford wrote:If everything the other guys told you is good then buy a dayco belt there v-belts are far superoir than anyone else.
Thats what I used to run and I would throw those just as easy as the cheapies until I put the moroso pulley on it. I found a smoking deal on an underdrive crank pulley and alt pulley and swapped and had no problems with that set-up either.
Re: throwing belts
What part number are you using now?
I switched to a narrower belt and mine stopped throwing them off.
BigBlockRanger- Posts : 1267
Re: throwing belts
x2BigBlockRanger wrote:What part number are you using now?
ive have spun mine to 6800 on spray with no problem i think its a 13mm
quick 52- Posts : 612
Re: throwing belts
I was using the stock replacement length don't recall the part number but I believe it was the 1/2" wide belt.
Re: throwing belts
thanks to all. i will try the alt. pully first and go from there
1fatcat- Posts : 44
Re: throwing belts
I haven't thrown a belt since I switched to serpentine in 1990.
ITSA 91- Posts : 2
Re: throwing belts
1fatcat wrote:thanks to all. i will try the alt. pully first and go from there
I'd try the crank pulley first.
Re: throwing belts
Im using a single crank pulley from DSC motorsports and a factory alt pulley using a gates 7340 belt and never threw it once in over 3 years even at 7k, Dennis makes a nice custom pulley.
nuclearcobra- BBF CONTRIBUTOR
» V belts vs. Serpentine
» The Wheelie King,,,,,,,throwing doors off !
» Danny bee belts
» Bearing Wear Question
» Belts (title is too short)
» Danny bee belts
