V belts vs. Serpentine
+9
466cj
peganit2
PROSTREET66
njstang87
torkair
13 posters
I know quite a few of you guys ditch the stock accessory setups, but given limited funds and a rather large engine bay which setup would be preferable? The reason I ask is because both of the builder 460 short blocks I have didn't come with ANY accessory brackets, or pulleys, or anything like that and need to find them either in the junkyard or perhaps someone here happens to have a set of brackets and pulleys taking up space in the back of their garage. The vehicle in question is a 73 Ranchero so I MUST have an alternator AND power steering and I would also like to have A/C if possible since I live in the middle of Arizona.
torkair- Posts : 404
Re: V belts vs. Serpentine
Either works fine for most applications.
Look for a late model Truck set-up, should be able to fine one in the JY.
Do you know what year they started using the serpentine setup on the 460?
njstang87- Posts : 106
1988 was the first year of serp.belt.
PROSTREET66- Posts : 245
Thank you sir. I know what to look for the next time I am in the junk yard.
Are the serpentine systems any deeper than the v-belt systems? I won't have a lot of room to work with up front.
7.5- Posts : 15
posted in wrong place.
torkair wrote:I know quite a few of you guys ditch the stock accessory setups, but given limited funds and a rather large engine bay which setup would be preferable? The reason I ask is because both of the builder 460 short blocks I have didn't come with ANY accessory brackets, or pulleys, or anything like that and need to find them either in the junkyard or perhaps someone here happens to have a set of brackets and pulleys taking up space in the back of their garage. The vehicle in question is a 73 Ranchero so I MUST have an alternator AND power steering and I would also like to have A/C if possible since I live in the middle of Arizona.
Vs. a Poly-Vee; the factory never made a true "serpentine" belt drive for a big block Ford.
If I had a choice I would always go with the polyv.
peganit2- Posts : 55
Another option is to adapt the serpintine setup from a Mustang with a 5.0L. A few guys have done it by using an adapter plate to bolt the 5.0L brackets to the heads. Other problem is this setup will turn the waterpump backwards. Never was a reverse rotation pump for BBF, but seems if you open up the cavity around the impeller on a BBF pump it works fine. Main advantage of this setup is saves some room at front of engine and is more compact. Steve
466cj- Posts : 391
466cj wrote:Another option is to adapt the serpintine setup from a Mustang with a 5.0L. A few guys have done it by using an adapter plate to bolt the 5.0L brackets to the heads. Other problem is this setup will turn the waterpump backwards. Never was a reverse rotation pump for BBF, but seems if you open up the cavity around the impeller on a BBF pump it works fine. Main advantage of this setup is saves some room at front of engine and is more compact. Steve
There used to be a site called bigblockfox.com that had all this info. Not sure if it is still around or not.
jasonf- BBF CONTRIBUTOR
There has to be a way to keep the water pump standard rotation and make it a true serpentine system, with three accessories. It would take quite a few idlers but I think it could be done.
Something like this could work with quite a bit of fabrication. Any arrangement of the accessories would work.
Not sure how in depth you want to get but here's what I ended up doing. Had to order a few small items at this point, but real happy with it. Don't have a completed pic yet.
Hangman- Posts : 32
res0rli9- BBF CONTRIBUTOR
WOW !!! Hangman . nice work there
Gregaust- Posts : 626
» Serpentine or v belt?
» serpentine belt set-up ?
» throwing belts
» Danny bee belts
» Bearing Wear Question
» throwing belts
» Danny bee belts
